Pin wear
Showing 1 to 6 of 6 results
kracked1
Looking for info on pin wear. I stretched the track tight with a pin in the sprocket. And measured 5 pins. I came up with 25.125" on both sides The link number is ITM?? 106-1 and 106-2 OM can you help me on this one? It is a D6B
Mon, Aug 23, 2021 3:29 AM
D4Jim
Here is a pin wear chart compliments of our good friend "Swishy".  I don't see anything that matches your measurements.  [attachment=64375]cattrackwearchartaf3 Red.jpg[/attachment]
Cats Forever
Mon, Aug 23, 2021 4:28 AM
kracked1
Reply to D4Jim:
Thank you, after rechecking my math it should be 27.125. That fits with my theory that there is minimal wear on this undercarriage.
Mon, Aug 23, 2021 5:11 AM
Reply to kracked1:
By Cat spec 27.10" is 27% worn, 27.15" is 37% worn
Mon, Aug 23, 2021 7:03 AM
robclay
Send a private message to robclay
Oh wow. My d6b measures 27.75.
Mon, Aug 23, 2021 7:17 AM
D4Jim
Reply to robclay:
[quote="robclay post=230841 userid=9425"]Oh wow. My d6b measures 27.75.
Robert, you are like a lot of the rest of us and run the tracks waaaaaay past what they should have.  Track work is expensive so if the machine is not used much no big deal until a track comes off!!
 [/quote]
Cats Forever
Mon, Aug 23, 2021 8:36 AM
Reply to D4Jim:
 [/quote]
That would be 130% worn. New hardened wear surface is only about 1/8" deep on most undercarriage components.
Mon, Aug 23, 2021 8:53 AM
