Photo's from a Bygone Era
Showing 1 to 10 of 935 results
seyser
Thank you received: 60
6-29-40
Levi H Yerger
Lititz, Pa
Caterpillar Diesel D2 tractor and LaPlant-Choate roadbuilder removing silt from creek bottom on a farm near Mt. Joy, Pa. This location in the stream is used as a ford for automobiles. The material is moved to the bank then loaded into trucks. Tractor working 10 hours a day on about 6 cents worth of fuel per hour.
[attachment=61293]IMG_2485.jpg[/attachment]
Mon, Nov 30, 2020 7:50 PM
seyser
1946
Michigan TR. & MCHY. CO.
Caterpillar diesel D4 tractor with trackson pipe-layer working on Marquette R.R. near Howell, Michigan.
[attachment=61294]IMG_2484.jpg[/attachment]
Mon, Nov 30, 2020 7:58 PM
seyser
Reply to seyser:
1946
Loop of 20-ton anchor chain is pulled by four Caterpillar D8 tractors to clear Ceylon jungle for Gal Oya project. Area to right has already been cleared by chain.
[attachment=61328]D8 Chain.jpg[/attachment]
Wed, Dec 2, 2020 8:39 PM
Thank you received: 99
Reply to seyser:
11-2-51
Hi, seyser.
Didda bitta that in my younger days, used everything from D4s to D8s. The 2 X D8s once took down 6,500 acres in 5 X 13-hour days - around 100 acres an hour.
It sure does help if you have a good man on the other tractor. LOL.
Just my 0.02. Thanks for sharing.
Thu, Dec 3, 2020 11:09 AM
seyser
Hi, seyser.
Hi Deas,
I’ll bet that was quite a job. Sounds like those D8’s would move at a pretty good pace.
Thu, Dec 3, 2020 5:36 PM
seyser
Reply to seyser:
Hi Deas,
August 15, 1947
Laying rails on new grade to serve roundhouse for the Chesapeake and Ohio Railroad (Pere Marquette District) Diesel locomotives in the "Wyoming" yards at Grand Rapids, Michigan. Caterpillar D4 tractor equipped with Hyster side boom handles 39' rails weighing 110 lbs. per foot. The D4 also works with stoneboat to distribute material for new trackage.
[attachment=61339]IMG_2508.jpg[/attachment]
Thu, Dec 3, 2020 7:39 PM
aaronloyet
Send a private message to aaronloyet
Great photos! Love seeing the one in Mt Joy, that is close by me in Lancaster 😊
Sat, Dec 5, 2020 8:58 AM
Reply to seyser:
Hi Deas,
Hi, seyser.
It was all 2nd gear work with 2 X 270 hp powershift D8Hs pulling 600 feet of 2 1/2" chain cutting around 400 feet wide in scrub 10 to 12 feet high - mostly only got to see each other at the end of each run. THAT is when you REALLY need a good man on the other tractor.
Sat, Dec 5, 2020 10:17 AM
seyser
Hi, seyser.
Caterpillar D8 tractor unloading scraper from rail car.
[attachment=61374]5D8D20E7-EF8B-41CE-9D8A-BB288A632B00.jpeg[/attachment]
Sun, Dec 6, 2020 3:58 AM
seyser
Reply to seyser:
December 31, 1942
[attachment=61413]62250A2B-F265-4F6C-B5B6-107A918E8B69.jpeg[/attachment]
Wed, Dec 9, 2020 4:44 AM
seyser
Reply to seyser:
Caterpillar RD-4 track type tractor with model Clair Taylor
Huntington Beach Beach 1937
[attachment=61735]86DF3B99-4257-4FEF-8A98-1DD2015AA36B.jpeg[/attachment]
Sun, Jan 3, 2021 10:02 PM
