Photos?
Showing 1 to 10 of 11 results
Mark Riendeau
Thank you received: 32
I was going post a couple photos. However, that function isn't working...again. Anyone know why? Is there a work around?
Fri, Jul 24, 2026 9:49 PM
Potato Wilson
Thank you received: 26
I took this photo the other morning because I liked the lighting. It was better live. Anyway, thought I’d do a little test here…
Fri, Jul 24, 2026 11:32 PM
Thank you received: 76
Pretty cool - does it run or yard art?
Sat, Jul 25, 2026 3:35 AM
Thank you received: 138
Hi, Potato Wilson.
Neat photo. The lettering on the radiator top tank appears to read, "RX". Am I correct and do you know the maker and/or any other details?
Sat, Jul 25, 2026 6:54 AM
Deebo
Librarian
Thank you received: 103
I still am only able to upload one photo at a time. Had hoped it’d be fixed by now. Will chase it up.
Sat, Jul 25, 2026 12:12 PM
Potato Wilson
Good morning gang,
It’s a RIX air compressor that we recovered from a gold mine when I was just a kid. It’s been yard art since, but it’s complete and is likely a good candidate for restoration. I’ve been meaning to put some oil in the cylinders. If I remember right it was made here in CA. I’ll have to check the manufacturer’s tag. I did some research at one time, and I think RIX is still in business making industrial compressors.
As far as posting photos, I’m on an Ipad, and doing one at a time I haven’t had any issues.
Sat, Jul 25, 2026 1:56 PM
Hi, Mark Riendeau.
As Deebo mentioned above, photo posting is still a one-atta-time, don't-be-greedy operation. Sometimes when you post it, the photo won't show up and all you will have is a small square with some'squiggles' in it. Wash, rinse and repeat usually gets the photo up on the second try. A PITA, I know but it's what we have at the moment.
Sat, Jul 25, 2026 10:24 PM
Mark Riendeau
Any updates as to the photo uploading issue? Does it continue? Was it taken care of?
Mon, Aug 24, 2026 10:42 AM
Hi, mark Riendeau.
Sad to relate, none that I have heard of. Deebo may have some better info.
Mon, Aug 24, 2026 12:23 PM
PNW.Hillbilly
Send a private message to PNW.Hillbilly
There appears to be a size limit on each photo you can post, around 1MB. Anything larger than that and you get the empty box.
Mon, Aug 24, 2026 2:24 PM
Deebo
Librarian
Multiple photos can now be uploaded! Takes a few tries and isn’t as reliable as it should be but better than it was.. just got to work on the abysmal search function next.. baby steps!
Mon, Aug 24, 2026 3:55 PM
