Perkins bleeding woes
Showing 1 to 6 of 6 results
Arborigine
Send a private message to Arborigine
I pressure bled my D2 injector system by pressurising the tank with no problem. Fired right up.
I have a Massey Ferguson MF30 with a Perkins AD-4 engine. previous owner passed on, and don't know why it wasn't running when i got it. I have followed recommended procedures and tried bleeding it (a lot) and starting it with no luck but do get fuel vapor from exhaust. I pulled an injector today to make an adaptor for my diesel compression guage at work tomorrow and when removing return line discovered that only two injectors were full of fuel. Has anyone tried pressure bleeding a perkins pump? or know if that will damage it? I will make a pressure tank to put 50-80 PSI in the system tapped in from the pump inlet, the pre-pump diaphram probably can't handle it.
Wed, Aug 31, 2011 10:55 AM
Mike Walsh
I don't know what make injection pump you have but you might want to look around on the pump for a bleed screw first. On CAV pumps I bleed the pump before I bleed the injectors. Its hard to pump fuel when the pump has lost its prime.
Wed, Aug 31, 2011 12:23 PM
Arborigine
Reply to Mike Walsh:
I have followed the procedure in the Perkins manual, and just haven't managed to get two injectors to bleed without running out of battery first. I'm hoping that once that is solved it will fire off. The system is a lot sillier than Cat's.
Wed, Aug 31, 2011 12:37 PM
AJ.
Send a private message to AJ.
Reply to Arborigine:
Careful,Cat own Perkins,I do not think that pressureizing the fuel system would be advisable,the CAV rotary pump is fuel lubricated meaning that the body of the pump is full of fuel and depends on a seal on the input shaft to keep it out of the engine,pressureize it and you may blow the seal out,start by making sure there is a unrestricted flow of fuel leaving the tank,take the top off the feed pump and clean the gauze and pump body,fit new filter/s,open all the bleed screws,one on each filter and two on the injector pump,get the engine turned till you have the feel the feed pump lever has pressure,prime till the first filter is air free then close the bleeder,do the second,bottom one on the pump and finish on the top one,keep on priming till the lever goes limp,loosen each injector pipe a couple of turns,with the stop in the run position and the throttle on full spin the engine over on the starter till there is fuel spurting from each union,tighten the pipes and try a start,watch the exhaust to see if its injecting fuel,if not it is possible that the metering valve is stuck in the stop position,this can happen if the engine is stopped and the stop been left pulled out,it is best to stop the engine and push the stop back and put the throttle on full when parking for a long peroid,thoes pumps are a SOB to bleed,you need a fully charged battery,good luck.
AJ
Wed, Aug 31, 2011 4:24 PM
ronm
Reply to AJ.:
AJ
CAV pumps are the hardest bleeding SOB's ever built-If a Perkins owner ever runs out of fuel, he will not do it twice... AJ has pretty well covered the procedure, just keep at it & eventually the damn thing will decide to run...
My old boss told a customer who called after having run his Massey out of fuel, "You have to bleed it". the guy replied, "I've bled everything but the damned SEAT!!!" 😆
Wed, Aug 31, 2011 8:57 PM
Arborigine
Reply to ronm:
Thats probably why i got it cheap. Story was Gramps lent it out, got it back not running and passed on before he got it to run. Borrower probably ran it out of fuel. Its a pain to do under the fuel tank and between the loader arms so i have a 1 gal can I made with fittings that i will use giving me a lot more room to see whats going on and swing wrenches. I have a fire extinguisher with firrings to pressurise liquids but will only try that as a last resort.
Thu, Sep 1, 2011 7:30 AM
Thank you received: 93
Reply to ronm:
on top of the CAV type injection pump you should find the fuel return line going back to the tank.
This line is usually connected to the pump by a banjo bolt type fitting, or a fitting that the return tube nut and flared tube screws into.
The bolt body can have either a relief valve that is made of glass--it is clear--and therefore looks to be straight thru, or an orifice in the side of it that is very hard to see. It is not unknown for the orifice to block up in time.
If it is blocked then it is almost impossible to bleed the pump body. The orifice, from memory, is only about 0.020" dia. and explains why it takes forever to bleed a full system of air.
Also agree AJ has given good advise.
Hope this helps.
