Parts needed!! d4 7u 1959
Showing 1 to 10 of 10 results
1941D4DOZERBOY
Send a private message to 1941D4DOZERBOY
Anyone have a pony motor starter v belt assembly or a starter for a d4 7u?? I have the starter/ oil fill bracket i just need the rest. i have the part i need circled in the picture. Any help would be great.
[attachment=57818]Inkeds-l1600_LI.jpg[/attachment]
Fri, Mar 20, 2020 7:06 AM
sandman
Send a private message to sandman
DozerBoy,
I have the part your looking for. It's going to need a bearing, it's yours for $50.
I'm in Oroville Ca Karl 530-282-4922
Fri, Mar 20, 2020 9:25 AM
ag-mike
Reply to sandman:
DozerBoy,
Anyone know modern replacement bearing part numbers? I want to change some out.
Fri, Mar 20, 2020 9:51 AM
1941D4DOZERBOY
Reply to sandman:
DozerBoy,
thanks karl ill call you
Fri, Mar 20, 2020 9:53 AM
1941D4DOZERBOY
Reply to ag-mike:
call florin tractor parts, Sacramento -->916-383-0317 he can get what you need for sure. you may need the part number i can help you with that if you need.
Fri, Mar 20, 2020 10:21 AM
GrantJ
Thank you received: 10
Reply to 1941D4DOZERBOY:
Do you have the flywheel with two belt grooves? Those brackets wont line the electric motor up with the normal single belt groove. Just asking??? Grant.
Fri, Mar 20, 2020 11:31 AM
Reply to GrantJ:
The 7F8661 bearing is a Fafnir 204KTD or NH brand 7020-KP
Fri, Mar 20, 2020 8:43 PM
ag-mike
I dont have it apart or book now, I imagine there are 2?, both the same? thanks!
Fri, Mar 20, 2020 9:02 PM
Reply to ag-mike:
No, the 7F8660 bearing [inner] is available from Cat $13.42
The 7F8661 is discontinued.
Fri, Mar 20, 2020 11:47 PM
Thank you received: 62
Try these numbers...both listed on ebay
7F8660 = 203-SS
7F8661 = WC87504
Sat, Mar 21, 2020 12:14 AM
ag-mike
7F8660 = 203-SS
7F8661 = WC87504
Awesome help! thanks.
Sat, Mar 21, 2020 12:41 AM
