Parts # matching ?
Parts # matching ?
951c
Send a private message to 951c
A guy gave me some new injector nozzles from a loader he used to own and said the motor was a 3304. the # is cat-5m4086 with an a stamped above it. What does this part # go to ?
Fri, Nov 9, 2012 3:21 AM
Thank you received: 30
chart below is what we used in the Fuel Injection Room at The Dealer to convert the Capsule Nozzle Part Numbers To Valve Service Group P/Nos when we needed to order a new nozzle.
Note :- you can only order a VSG thru Cat Dealer Parts Departments.
Hope this helps.
Fri, Nov 9, 2012 6:28 AM
josh
Thank you received: 13
Reply to edb:
Hope this helps.
Used on 46A, 60A, 22B, 15A, 53A, 23B, 14A, and many more applications, if you post a machine sn I can check.
Fri, Nov 9, 2012 7:19 AM
Thank you received: 43
Reply to josh:
For reference.........
Fri, Nov 9, 2012 11:59 PM
