parts interchanging? D4 7u
Showing 1 to 6 of 6 results
tommyt
Send a private message to tommyt
I have a 1951 D4 7u that use almost daily. i have found a 1956 machine and was wondering if the pony motor and tracks will fit my current machine? thanks and any help on other parts fitting will greatly be appreciated.
Sat, Apr 13, 2013 1:18 AM
Inter674
Looking at the parts manual most parts should swap straight over including the pony. The tracks too provided they are the same length. Are both 5 roller track frames and heavy duty type? Others will know more than I but I recently re-built a 58 7U using parts from 2 other 7U's that were much much older and apart from some cosmetic aspects where Cat had improved engineerings etc, all parts were a straight swap.
Sat, Apr 13, 2013 4:07 AM
tommyt
Reply to Inter674:
I have not seen it yet. the main part I want is the pony motor in case mine gives trouble. Thanks
Sat, Apr 13, 2013 11:02 AM
Oil Slick
Reply to tommyt:
If you don't live in extreme cold and you use your D4 regular you might consider putting direct start on it. A MT 40 starter cost about $300. A lot cheaper then rebuilding a pony. It's so nice to get on and push a button and its running.
Sat, Apr 13, 2013 9:02 PM
Dozerman51
Reply to Oil Slick:
If he decides to go direct electric start, he'll have to drill the bellhousing for the starter. A 1951 D4/7U did not have the bellhousing drilled and covered with a plate yet from the factory.
Sun, Apr 14, 2013 12:34 AM
tommyt
Reply to Dozerman51:
He is correct I would have to drill my bell housing. I really like the pony. Mine starts fast and I don't think I could drill the hole in the correct location. The starter you are talking about Will it come with the correct end for $300? Thanks
Sun, Apr 14, 2013 5:06 AM
Thank you received: 22
Reply to tommyt:
No, you will still have to change the drive end housing...about $35 and get the RH Helical drive....about $90.
Sun, Apr 14, 2013 6:35 AM
