Shows up for me in the library:
[attachment=71951]parts.png[/attachment]![]()
In my microfiche the 4b666 and 4b671 is the same block
Thank you all for posting these! Not sure why I missed these in my initial search....
Unfortunately none of these manuals list the block as 4B666 which is what's on my D4 - I suppose it was swapped out at some point. Does anyone know which parts manual would cover the 4B666 block assembly?
[quote="Dirtbiker1824 post=247775 userid=16071"]Thank you all for posting these! Not sure why I missed these in my initial search....
Unfortunately none of these manuals list the block as 4B666 which is what's on my D4 - I suppose it was swapped out at some point. Does anyone know which parts manual would cover the 4B666 block assembly?[/quote]
I’ve had a brief look through the D4/D2 parts catalogs and can’t see the “so called Devil block” listed as 4B666, nearest I see is 4B671. I’m never sure if the numbers on the actual castings correspond to the part numbers or are just casting numbers. Might be worth PMing Sasquatch as he’s done extensive YouTube (Squatch253 on YT) starting engine stuff. This link will get you started; https://youtu.be/eeR66ciRnDk
The good thing is a lot of parts for all these pony motors are totally interchangeable and you may find even if you find a parts catalog for that block someone may have changed the top cover or other things at some point.
[attachment=71975]649F870F-276F-4EF3-8EC4-6B5FD6371908.png[/attachment]![]()
Dirtbiker, the casting number is not (necessarily) the part number. Your block has the tractor serial # on it so use the catalog posted above to find parts for your block. You don't have to overthink it : )
4B666 is the casting number, the block assembly is 4B671.
according my 6u parts book its the top cover and exhaust manifold thats different and thus a different gaskets for those parts. but the block itself is the same and it was only for the first 700 machines.
but that doesnt mean anything as the early machines could have been "upgraded" to the later setup. as it all just bolts on.
