Parts Book for D7E Lift Cylinders?
Magneto
Send a private message to Magneto
Is there a book available that lists the parts for the blade lift cylinders? I am looking for the part numbers for the swivel part (trunnion?) bearing halves on the rod end of the cylinder and the bushings on the cylinder pivot that allow the cylinder to swing from side-to-side. The hydraulic system on this tractor is a model 173 mounted in front of the radiator. The parts book for the 173 system doesn't list these parts. The tractor is a direct drive low horse serial 47A1294.
Any idea what year this tractor was made?
Fri, Mar 28, 2025 1:15 AM
Thank you received: 54
do you know what model blade it is there may be a book for the blade itself. yes that bit is called a trunnion in engineering circles.
Fri, Mar 28, 2025 1:56 AM
Magneto
After some more research I think that the trunnion bearings are part number 3J5689 or 2h6473.
I haven't found anything on the other parts.
I don't see any numbers on my blade.
Thanks for the reply!
Fri, Mar 28, 2025 2:11 PM
Thank you received: 64
For that early a s/n the swivel bearings are part # 3J2443 and the rod end trunnion is #3J5751.
Can be found in Parts Book Form #UE035033
47A1294 is a 1963 build.
Sat, Mar 29, 2025 12:05 AM
