parts and pieces for my 212 grader
moonshadows
Send a private message to moonshadows
have been using my 212 {1u166} lately and need to get some parts / help with part numbers i want a new set of scarifier teeth found some cat knock offs on ebay part #9F5124 will these fit my machine? i contacted seller and he cant find my 212 in his book i want to replace the cutting edge on the mold board too anyone have an old part number for that ??? i think i found the fuel filters and the oil filter but i would like to confirm before i buy them so if you can help with napa / cat numbers for those that would be great and how much oil for the engine ??? thanks in advance --- scott
p.s. after never finding a good source for the 10.00 24 rear tires i used some used 11r 24.5 truck tires on the back and they have been working great for about 2 years but now that i have finally got the trans to let me use 1st gear the extra torque {and it could be that the tires are old dry and junk to start with} is really pulling the tread off --- the local county dump has lots more and free is still cheaper than buying new ones if i ever find them !!!
Sat, Feb 25, 2012 10:56 PM
Your grader will have a D3400 engine, also used in the J series D2 tractors, which could have an original bypass filter or have been converted to a full flow version or even have had a factory full flow version. If you will do a search on here or over on ACME, there has been a lot of discussion on how to determine which you have and how to convert a bypass to a full flow. I would start with taking whatever is in it out and looking for numbers, but check it out carefully, because there have been some show up which were not properly converted and they do not function as either kind! Here's an excellent resource Ron (OzDozer) put up over on ACME's "submissions" archives.
http://www.antiquecaterpillar.net/ACF_v2/showthread.php?t=13442
The D2 tractor specs show 13 quarts of oil. Your grader should be similar. Pony motor takes 1 quart and you've got a couple of oil bath air breathers to clean as well, so I would start off with 5 gallons.
If you could find some military tread 24.5's that should set you up pretty well. Might check with Gensco. They usually have military surplus or recaps with that tread.
http://www.noflats.com/
Still it's hard to beat free!
Sorry, I can't help on the part numbers.
I traded our 9T 212 off and the manuals went with it, so I can't help on the cutting edge part numbers. Lots of times, you can go from the hole spacing, thickness and width to get one aftermarket or we can sometimes get take-offs from the county that are still wide enough to do what we need. A CAT dealer should be able to look it up for you if you can't find it by the dimensions.
Sun, Feb 26, 2012 1:41 AM
Thank you received: 60
Yes, the 9F5124 fits the 212 grader, uses the 2D5572 or 6Y5230 tooth.
This is a front notched shank, they also have a rear notched version 5B0947 depending on what your machine uses.
All use the same wedge #1D3537.
Sun, Feb 26, 2012 10:37 AM
moonshadows
[quote="ccjersey"]Your grader will have a D3400 engine, also used in the J series D2 tractors, which could have an original bypass filter or have been converted to a full flow version or even have had a factory full flow version. If you will do a search on here or over on ACME, there has been a lot of discussion on how to determine which you have and how to convert a bypass to a full flow. I would start with taking whatever is in it out and looking for numbers, but check it out carefully, because there have been some show up which were not properly converted and they do not function as either kind! Here's an excellent resource Ron (OzDozer) put up over on ACME's "submissions" archives.
[/quote]
thanks for the info on the oil filters the link was helpful and ill pull mine apart and see what i really have !! i can subtract the quart for the pony and whatever the air cleaner on the pony took -- mine would be be used as a boat anchor only reason it is still bolted on is i dont feel like fabing a plate to block the water passage off.
Sun, Feb 26, 2012 10:37 PM
moonshadows
[quote="Old Magnet"]Yes, the 9F5124 fits the 212 grader, uses the 2D5572 or 6Y5230 tooth.
All use the same wedge #1D3537.[/quote]
happy to hear the ones i found are the right ones they are front mount --- scott
Sun, Feb 26, 2012 10:45 PM
CarlsCAT
Send a private message to CarlsCAT
Reply to moonshadows:
I have a couple of CAT 212 9T Graders...I got my Cutting Edges for the moldboards from a local CAT dealer...Fuel filters also from CAT...and Florin...The plow bolts for the moldboard may need to be replaced when replacing the cutting edges...I had to cut some of mine off with a torch...Plow bolts can also be bought at CAT...or maybe John Deere and such...There's a forked tool for removing the scarifier teeth...I found one on e-bay...CAT 212 1U Motor Grader manuals can be found on e-bay...or from some other CAT manual providers...Just do an Internet Search for them...
Mon, Feb 27, 2012 12:42 PM
| Kingaroy, Queensland
