Part numbers and tracking superseded part numbers
Showing 1 to 6 of 6 results
holt 2 ton
Send a private message to holt 2 ton
Hi how do I find the new part numbers to quote when ordering parts when the part number in the book has been superceded and is no longer on the parts listings???any help would be appeciated.. The part numbers in question is 1A7491 and 1A7501.
Wed, Mar 14, 2012 1:36 PM
ianoz
Mark , Look at your visitors messages .
Wed, Mar 14, 2012 4:43 PM
Lance Jones
Hi 2 Ton Holt , Order as per your Book nos. The numbers you give , as you showed ,will update on Dealers computer and they can order accordingly OK. However if you are dealing with early Parts Eg 10 and 15 Parts you need to change the Following . EG Part no V272 add an 0 in front of V and an 0 in Front of 2 = 0V0272. many of the wiz kids on parts do not understand . Parts must have 6 Digits to register . New machines now have all Numbers. Have a look at Cat Bolts for example , you will note the above info shows up very Often eg an 1 1/2" x 7/16" was T772 now it is an 0T0772 .
Hope this helps you LJ
Wed, Mar 14, 2012 4:57 PM
Thank you received: 73
Reply to Lance Jones:
I'm looking at some of the part numbers in the For Sale section, and wondered if there is a resource that we can use (before calling the dealer) to look up superseded part numbers? Would getting a Cat account enable that look-up?
Neil.
Wed, Nov 13, 2013 9:44 PM
Neil.
Tried my online Cat parts store and it says part # superseded and to call dealer
Thu, Nov 14, 2013 3:24 AM
chriscokid
Reply to dpendzic:
you can try this: http://www.tpaktopc.net/cgi-bin/Cat_Part/Cat_Part.cgi
Thu, Nov 14, 2013 3:57 AM
josh
Thank you received: 13
Reply to chriscokid:
Those two part numbers have been out of the system for a long time, the last note of them at all that I could find, was a price on the 1A7491 from 1958, and on the 1A7501, it updated to 6B5516. In about 1968, listed with the note that the part was unreturnable, which I believe meant it was discontinued and the last of old stock.
Thu, Nov 14, 2013 10:36 AM
| Kingaroy, Queensland
