part number tool bar pipes
Showing 1 to 7 of 7 results
HOLLANDCAT
Send a private message to HOLLANDCAT
Hello ,
I am fitting a No6 tool bar blade on a D6 9U 23008.
All i am missing is the oil lines from the No44 hydraulic control to the fenders .
I need the part number's from the 2 double oil lines . ( on the left and on the right side from the engine)
Thank you , Gilbert
Tue, Nov 28, 2017 12:24 AM
My info does not show the split pipe (down each side) for D6 applications. When two pair of lines are utilized they use the later #44 with the lines on one side.
Tue, Nov 28, 2017 1:57 AM
HOLLANDCAT
I have the No44 with serial number 7V5866 that have the connection on top that goes both ways.
When i have a part number , there was a chance to have the right specs on these .
Now i gone try to make these myself .
Thank you Old Magnet ,
Gilbert
Tue, Nov 28, 2017 3:47 AM
johan7
Reply to HOLLANDCAT:
Gilbert
[attachment=45818]36. 9U tool bar .jpg[/attachment]
Hello G , probably this is the model you are going to imitate . Is your number correct ? My book shows 7W no 44 control . Anyhow , I don't think Cat will have this in stock .
Good luck , J
Thu, Nov 30, 2017 8:27 PM
ag-mike
Reply to johan7:
Good luck , J
is this the first d6 toolbar machine we seen?
Fri, Dec 1, 2017 3:22 AM
HOLLANDCAT
Reply to ag-mike:
Hello Johan7
I need the part Numbers from these pipes , that i can get factory drawings.
I have a No44 hydraulic unit with 7W , but i would like oil pipes on 2 sides from the engine .
Also have a No44 with serial no 7V , thes have exits to both ways .
Of course i have not seen this here before.
Gilbert
Fri, Dec 1, 2017 3:45 AM
johan7
Hello Johan7
Gilbert
Hello Gilbert , my book ( form 30032 ) covers ONLY the toolbar system for 4R and 5R machines .
But I know that long ago Hoogendijk had a toolbar machine . Perhaps Gerard still has the right book .
I hope they can help you . If you want copies of the pages of my book , then let me know .
Have a nice day , J
Fri, Dec 1, 2017 10:04 PM
dtallon
Send a private message to dtallon
Reply to johan7:
Have a nice day , J
I agree with OM, I can't find anything that shows a setup on a D6 that has a set of pipes going down each side, only that kind of setup for a D4. Parts book for the 7W on a D6 U-series shows 1J1274 as the group for the first valve, and 1J1273 as the group for the 2nd valve. Tube assemblies running along side of the engine would be within those groups. Crossover lines group for the LH cylinder on the toolbar is 1J1276.
Dave
Sat, Dec 2, 2017 2:02 AM
