part number help
part number help
1arock
Send a private message to 1arock
I need the part number for the seal in the torque convertor case for the drive shaft going to the CCU. D7E 48a 3165. Any help appreciated.
Fri, May 30, 2025 8:01 PM
Thank you received: 55
if your a paid up member you can check the tech library for a parts book it would be listed there. im currently not so i cant check for you.
Sat, May 31, 2025 2:46 AM
1arock
I have the parts book for the tractor and CCU and can't find it in either one?
Sat, May 31, 2025 3:02 AM
Same seal as used on the D8 shaft for the #29 CCU part # 3J0369
Sat, May 31, 2025 6:41 PM
1arock
Thanks sir
Mon, Jun 2, 2025 11:35 PM
