Part no for catd5b 98j tool bar hydraulic cylinder
Showing 1 to 10 of 12 results
Ianlr
Send a private message to Ianlr
I need a part number for the hydraulic cylinder used for the toolbar blade on a D5B 98J. While i have allegedly every operation, maintenance, spare part, technical bulletin and special instruction manual for this dozer there is no reference to part numbers. REG00684-03 shows how to assemble and disassemble the cylinder. About halfway through under the heading Cylinders there are diagrams of the rod end that show the packing rings, retainer and rod wiper seal. I have smashed the retainer which is cast iron. There are no numbers stamped on the retainer but on the cylinder there is VBS8089. This number means nothing to Hastings Deering, my local Cat dealer. They also had never seen or heard about toolbar blades. Can anyone help me please?
Ian
Wed, Nov 18, 2015 6:36 AM
Thank you received: 46
Is there a s/n tag anywhere on the toolbar unit?
Should be on the forward face of the swivel upright.
Wed, Nov 18, 2015 7:00 AM
Ianlr
None that i can find where i can see without disconnecting the blade. My local dealer is still searching and hopefully seeking help from Caterpillar who must have something on this. In the meantime I am starting to think about sourcing a third party cylinder of similiar stroke and bore. I assume i would have to have fairly similar so that the blade moves level?
Wed, Nov 18, 2015 7:28 AM
Reply to Ianlr:
This is what I show for the #5 & #6 tool bar with s/n 76C1-up and 34C1-up.
Wed, Nov 18, 2015 7:37 AM
Ianlr
Thankyou for your help. However it doesn't look right and I am starting to wonder whether I have in fact got a genuine cylinder. My local dealer has come back also with something different again that also doesn't look right although the design is similiar. I've asked for availability and price on the retained part number 2J3860 Retainer. I will try attaching the pdf they sent me when I work out how to do this.
Ian
Wed, Nov 18, 2015 11:48 AM
Ianlr
Reply to Ianlr:
Ian
[attachment=32143]scan.pdf[/attachment]
Hopefully I have attached a copy of the pdf my local dealer sent me. As noted in my last t doesn't lok right but the design of the retainer at the rod end is similiar.
Ian
Wed, Nov 18, 2015 12:08 PM
Ianlr
Reply to Ianlr:
Ian
Attached 2 photos to clarify what my setup looks like
Ian[attachment=32144]DSC_1802.jpg[/attachment][attachment=32145]DSC_2074.JPG[/attachment]
Wed, Nov 18, 2015 12:45 PM
Ianlr
Reply to Ianlr:
The last bit for a while - my local cat dealer is quoting me AU $250 ex USA 7-9 days for what could be the wrong part. Now looking for a complete second hand third party hydraulic cylinder.
Wed, Nov 18, 2015 1:04 PM
Reply to Ianlr:
That does not look like the typical Cat manufactured tool bar arrangement.
Wed, Nov 18, 2015 1:06 PM
Ianlr
That's what I was starting to suspect.
Thanks for you help though. At least I got to work out how to post images on the forum.
Wed, Nov 18, 2015 1:12 PM
ag-mike
Reply to Ianlr:
aftermarket?
Wed, Nov 18, 2015 7:51 PM
