Pad Wear
hb11
Send a private message to hb11
What typically wears out first on an undercarriage? My sprockets, rails, bushings, idlers all look much less worn than the pads. Pads are about 40% worn and the rest don't look hardly worn at all. Is this normal?
Fri, Dec 29, 2006 10:04 PM
SJ
Send a private message to SJ
Maybe someone rebuilt the complete under carriage but used the old pads which some do so I,m thinking maybe that,s what was done with yours unless you have had the tractor since new & have the history on it.Also where & what the tractor was used in will contribute to pad wear & other parts too.
Fri, Dec 29, 2006 10:14 PM
