Overheated diesel engine in D69U
Showing 1 to 10 of 19 results
MetalmanD69U
Send a private message to MetalmanD69U
Hello, I wonder if I can get some opinions here; D69U-9023
While discing a field this spring, I allowed the D318 to get a 'little' hot. I had been monitoring the coolant temperature gauge and it was climbing on the uphill sections but going back to normal downhill or level. Long story short, I let it get too hot on the gauge, stopped working to let it idle and cool down. At that point it was running rough at idle whereas it was not prior.
The gauge temp went down so I got back to work.
Well it heated up again fairly soon, and I noticed it was blowing 'white smoke' out the exhaust. Shut her down, checked the coolant in the rad, none showing, went back later with jugs of water when the engine was cool .
Added about 5 gallons, drove it back 1/2 way to the farm shop. Did the same the next day (added 5 or 6 gallons of water again)
Finally had time to pull the head off today, hoping to see a bad head gasket, but nothing obvious is evident.
There are no obvious cracks in the head or the block, the head gasket does not show any leaky areas.
I did find a small amount of coolant in 3 cylinders (maybe leaked in when I removed the head?)
The intake and exhaust ports do not appear 'wet'
There is no apparent coolant or water in the engine oil when checking with the dipstick.
One thing I found but don't understand; there appears to have been a little coolant leaking out around some of the injectors on the combustion chamber side of the head.
Any ideas?
Sat, Jun 29, 2019 11:59 AM
ianoz
Check your precombustion chambers , they rust and let water into the cylinders .
Sat, Jun 29, 2019 12:37 PM
MetalmanD69U
Reply to ianoz:
Thank you ianoz, I will do that.
Sat, Jun 29, 2019 12:45 PM
Chronic leakers will have rust and pits vs black carbon on the head. Check carefully for cracks in the pc chamber-intake-exhaust triangle.
When you get it back together it may still overheat on a disk. You may want to just go ahead and rod out the flues of the radiator core before even trying to run it. I have a 9u we were using on a root rake, maybe babying it a little to keep from overheating. Soon as we put it on a disk, it was boiling!
Tried rad cleaner (quart of Muriatic acid) with no improvement, so bit the bullet and pulled the top tank off to clean the flues properly. Found a couple handsful rust flakes laying on the top of the core clogging the flues and about 80% of them plugged. We were able to get that down to 10% without resorting to drilling and blasting. It has stayed cool ever since.
Sat, Jun 29, 2019 4:34 PM
MetalmanD69U
[QUOTE=ccjersey;225317]Chronic leakers will have rust and pits vs black carbon on the head. Check carefully for cracks in the pc chamber-intake-exhaust triangle.
Thank you ccjersey, I did not suspect the inside of the rad. Now I know to check that.
Sat, Jun 29, 2019 11:51 PM
Reply to MetalmanD69U:
Check the obvious first. They are notorious for having the fan belt slip.
Sun, Jun 30, 2019 1:36 AM
MetalmanD69U
Thank you sir, I will keep an eye on that too.
On a related note, I am planning to swap the damaged fixed blade fan (on removal, noticed that a couple of the blades had been bent and crudely straightened)
for an adjustable type off a parts machine we have here. Long shot, but as the fan blades were still a bit bent, maybe they were not moving air efficiently.
Always assuming the spare is in better condition of course
Sun, Jun 30, 2019 2:04 AM
Thank you received: 62
The first place a 318 engine loses coolant is pre combustion chambers ether rusted or the seal surface and washer are bad. Unless you know the history probably time to rod out the radiator.
Sun, Jun 30, 2019 5:47 AM
MetalmanD69U
Reply to Ray54:
Thank you Ray54. It is good to have knowledgeable folks suggesting similar things to watch for, very much appreciated.
Looking forward to getting back on it tomorrow.
Another pleasant surprise; Finning Caterpillar had a "valve grind" gasket and seal set in stock, picked it up today, also a valve spring compressor from the local dealer of made in China merchandise. The gasket set was quite pricey but to me it's amazing to find o.e.m. parts on the shelf for a 70 year old machine.
So to rod out the rad, it has to be removed from the machine?
I understand that the top of the rad can be unbolted, is the same for the bottom?
Or do you just rod and flush from the top?
Regards.
Sun, Jun 30, 2019 1:28 PM
TomTrack44
Send a private message to TomTrack44
Regards.
My D6 started overheating after discing for several hours, would run a little hot, then cool down on flat ground. The next day did the same only would not cool back down, was not in the red but was hotter than it had been running for several weeks. That evening when I shut it down, I saw the fan rotate a little after the engine stopped, what the? Went over and could rotate the fan by hand without moving the pully. tried tightening the belt a little, would not go enough to reach the correct position, time for a new belt! Installed new belt and it has run fine since. Glad it was the belt; though it is a bit to get it changed, took a while to let the loose juice do its job so the adjusters could be moved enough to get the old one off and the new one on. Good luck with yours. Tom
Sun, Jun 30, 2019 8:57 PM
gemdozer
Thank you received: 25
Reply to TomTrack44:
Make sure too when you change the belt then the rim and hub are't too worn because the belt will be in damage soon
Sun, Jun 30, 2019 9:27 PM
