Oven baking a magneto
Showing 1 to 7 of 7 results
Haole Cat 1
Send a private message to Haole Cat 1
Aloha,
I have a bit of moisture in the mag. Has anyone ever actually baked one in an
oven before?
If so, how long, plastic cover on or off? And what temp? How long?
Thanks!
Sun, Aug 29, 2010 3:48 AM
gemdozer
You should't do this you better use a hair-drier because in the oven
you could get probleme.
Sun, Aug 29, 2010 4:53 AM
zootownjeepguy
Reply to gemdozer:
Magnetos are used to being stuck on a hot engine at temperatures of 190 degrees or more. I don't see what harm could be done by baking them in an oven at that temperature for an hour or two. I'd get a spare mag first just to be safe!
Rich Salvaggio
D2 5U9917
Sun, Aug 29, 2010 8:10 PM
Dandy Dave
Send a private message to Dandy Dave
Reply to zootownjeepguy:
Watch that you don't melt the coil! Dandy Dave!
Sun, Aug 29, 2010 9:18 PM
ol Grump
Rather than baking it, I'd take the cap/coil off and hose it and the inside of the mag down with electrical cleaner, set everything outside and let it dry. That should get rid of any moisture and grease. Be careful, some of the cleaners are highly flammable so you might want to do any spraying outside in fresh air.
Sun, Aug 29, 2010 9:33 PM
Atlas
Send a private message to Atlas
Reply to ol Grump:
48 Hours placed on top of a warm oven will dispel all moisture out of Mag. Very high temperatures may do more damage than good. good luck Atlas
Mon, Aug 30, 2010 4:16 AM
Haole Cat 1
Reply to Atlas:
Mahalo from Hawaii, were's there's never a shortage of moister and corrosion!
I tried at 100, no problems..
J\
Mon, Aug 30, 2010 10:15 AM
Rd6 plower
Send a private message to Rd6 plower
Reply to Haole Cat 1:
J\
If you use starting fluid on the cap it will take the moisture out but let it dry before you put the cap back because it could blow to peices.
Mon, Aug 30, 2010 10:10 PM
