OT Source For Cultivator Shanks
Showing 1 to 10 of 10 results
sheddcanyon
Send a private message to sheddcanyon
Can anyone recommend a source for an older style cultivator shank? I tried Wasco and they showed a part # but they don't have them anymore. [attachment=71545]cultivator shank.jpg[/attachment]
It's 15" +/- from top to bottom.
Mon, Mar 20, 2023 11:52 PM
D4Jim
Try Shoupparts.com. located in IL
Cats Forever
Tue, Mar 21, 2023 1:49 AM
Thank you received: 289
Reply to D4Jim:
I wonder if Domries in Madera, CA could hook you up. Isn't that called a "Danish" tine?
Tue, Mar 21, 2023 8:11 AM
LimaGrower
Send a private message to LimaGrower
That is a danish tine. Call Bryan Equipment in Gonzales CA. Ask for Alan. He will have them. I also think our Deere dealer has them.
Tue, Mar 21, 2023 8:46 AM
steeltracs
Thank you received: 10
Reply to LimaGrower:
Spring tooth cultivator shank, not a danish tine similar but different.
Tue, Mar 21, 2023 11:57 AM
Thank you received: 55
Reply to steeltracs:
try your nearby bareco stockist eh bare and co supply a lot of that sort of stuff. so do asp products. any good engineering shop or blacksmith should be able to fashion you some out of plain flat spring steel bar. the art is in tempering the steel after shaping
Tue, Mar 21, 2023 4:30 PM
Reply to trainzkid88:
I dont think that style shovel is used on that single shank, should be single narrow shovel without the sweeps.
Tue, Mar 21, 2023 8:33 PM
This is a Danish Tine
https://www.facebook.com/marketplace/item/737950474379414/?ref=search&referral_code=null&referral_story_type=post&tracking=browse_serp%3A432515de-343f-4e18-846e-728f71b14f74
Tue, Mar 21, 2023 8:36 PM
This is a Brillion type
https://www.facebook.com/marketplace/item/763780984986879/?ref=search&referral_code=null&referral_story_type=post&tracking=browse_serp%3Adce1aa51-e12f-4b0f-acff-b9b96efb32c7
Tue, Mar 21, 2023 8:46 PM
sheddcanyon
Thank you all! I'll start calling.
As to whether the sweep is correct, it's what came with the cultivator. Of course, no brand name or model number to be found.
Tue, Mar 21, 2023 10:38 PM
Reply to sheddcanyon:
I think any dealer that sells "Perfecta" tillage equipment would have similar as well. You can buy all types of sweeps or points from most farm equipment dealers. Good luck in your search. JM
Tue, Mar 21, 2023 11:06 PM
