OT - manual planetary gearbox
Thank you received: 12
Folks, is anyone aware of a transmission that is like a planetary powershift, but instead of hydraulics to actuate the clutches and brakes, the transmisison used levers and over-centers?
Tue, Apr 25, 2023 9:13 PM
Thank you received: 11
Not sure I am able say for sure about the concept your asking about. But the early self propelled New Holland swathers (model 905 and 907 and maybe others) used a planetary gear box on each drive wheel. Each wheel had a stick, pushed forward it engaged a clutch pack for the planetary gears for forward motion and locked over center. Pulling the sticks back passed neutral it engaged a brake band and reversed you. I was told it had a lot of similarity to a Ford model T transmission in how the reverse worked.
Tue, Apr 25, 2023 9:31 PM
Reply to Ray54:
Ah yes, thanks for responding Ray. Now that you mention it, I seem to recall something about the Model T gearbox being planetary and no hydraulics
Wed, Apr 26, 2023 12:58 AM
Haus
Send a private message to Haus
I think that's also how Lenco car transmissions work. Not sure if the actuation is a band, but seems to be manual.
Paul.
Wed, Apr 26, 2023 9:17 AM
Reply to Haus:
Paul.
Funny you mention that Lenco Paul, I remember seeing some character on youtube put a six stage together out of Lencos and wondered if they were planetary based on the housing shape
Fri, Apr 28, 2023 7:53 AM
Veerkamp Open House 2025
| Placerville, CA
Stradsett Park Vintage Rally
Chapter 2 The Link Club's AGM
