Original Cat 16 Grader Specs
1972RedNeck
Send a private message to 1972RedNeck
Does anyone have a list of specs for the original 16 Motor Grader? I have found the weight and moldboard width (obviously) but that is it. By the looks of it, it has the D343 engine - must be at least 250 HP?
Tire size?
What transmission do they have? It looks like a 3 speed with another lever with 3 speeds as well - same as the old 830M wheel dozer?
Tue, Jul 16, 2019 11:15 PM
Thank you received: 50
I only have engine, driveline and controls specifications, not overall machine.
Looks like tires can be an issue, might plow through this HEF discussion
https://www.heavyequipmentforums.com/threads/replacement-tire-options-for-a-old-1970-cat-16-with-18x20s-rock-lug-40-plys.25665/
Tue, Jul 16, 2019 11:51 PM
terrywelch_archive
I have a 16 49G269. So far we have changed the head and rad core. The cooling system holds 21 gal. We Are also changing the transmission fluid. Trans fluid is 30 weight. Ours has a different tire than listed. When I get to my bolt later I can give you some informations
Wed, Jul 17, 2019 2:30 AM
Reply to terrywelch_archive:
Cat 16 49G series made from 1963-1973, 225 hp, approx. shipping weight 49,600 lbs, wheel base 22' 6", length 31' 2", width 9' 10", moldboard length 14', turning radius 44' 6", max speed forward 30.9 mph
Cat 16G 93U series made from 1973-1995, 275 hp, approx. shipping weight 60,150 lbs, wheel base 22' 10", length 32' 8", width 10' 1", moldboard length 16', turning radius 27', max speed forward 27.1 mph
Wed, Jul 17, 2019 7:40 AM
I believe the 49G would have had a D333 engine then went to the 3306. Not sure though.
Wed, Jul 17, 2019 8:10 AM
The 16 49G uses the D343T @225 hp
The 16G 93U uses the 3406T starting at 250 hp and later was raised to 275 hp
Wed, Jul 17, 2019 9:22 AM
Thanks for clarifying that Mag. Thought that was a little high hp for the 3306 at 275. Gary
Wed, Jul 17, 2019 9:22 PM
greghill25
Send a private message to greghill25
[quote="Old Magnet"]The 16 49G uses the D343T @225 hp
The 16G 93U uses the 3406T starting at 250 hp and later was raised to 275 hp[/quote]
Good info Old Magnet, thought the 16G only had 250hp.
Thu, Jul 18, 2019 9:37 AM
1972RedNeck
What is the transmission arragnement on your old 16? How many gears? Powershift?
Wed, Mar 4, 2020 9:08 PM
