opinions on HD -41 allis
Showing 1 to 6 of 6 results
boots
Send a private message to boots
just wondering about the hd 41 allis should have been a horse in its day with 524 hp any opinions on weak or strong point i guess cabin fever setting in found a broucure in the filing cabinet boots?
Wed, Dec 28, 2011 4:14 AM
Thank you received: 113
Hi, Boots.
When these contraptions hit the market, they were the biggest crawler tractor/bulldozer available. They were able to rip travelling UPHILL and could WAY outwork a D9G, Cat's biggest dozer at the time - - - - - - WHILE they were working.
They tore up final drives and tracks with gay abandon in heavy work like hard ripping and dozing rock - - - to the extent that a couple of companies DowNunder who had them de-tuned them by around 80 to 100 horsepower.
From the few reports that I have heard, the Fiat-Allis 41B was a better tractor but not by enough to save the model line.
Hope this eases your curiosity.
Wed, Dec 28, 2011 5:01 PM
boots
Hi, Boots.
believe you are saying they were built light for the power they had thanks for the reply boots
Wed, Dec 28, 2011 8:06 PM
willitrun
Send a private message to willitrun
Reply to boots:
cabin fever got me also. typed in russian bulldozers and up comes a t100 that looks and sounds like a 3t cat. right down to the pony motoršŸ˜–hocked:
Wed, Dec 28, 2011 8:20 PM
grandpa d9
Send a private message to grandpa d9
Reply to willitrun:
http://youtu.be/XTBPGveyA2U
http://youtu.be/dp4-ScDRqCk
here 2 video of the FIAT ALLIS
Thu, Dec 29, 2011 4:45 AM
Reply to grandpa d9:
Hi, Boots.
Rye Tonn. That was my first thought about them when I first read the specs on them, back in 1971. They had 140 more horsepower than the D9G and were only about 6 - 8 ton heavier. A D6D has 140 hp and it's a bit more than 6 - 8 tons. By the time you gear a powerful engine, even a comparatively slow-revving one, down to the speed of a crawler tractor, it takes a fair bit of VERY GOOD steel AND a fair bit of engineering to keep that generated force directed through to the sprockets and down to the ground and stop it from tearing things apart along the way. For many of the manufacturers who are no longer with us, that was at least a part of what brought them undone - they could not master that little trick.
Even Cat have built some back ends that were not quite as robust as they might have been and even the MIGHTY D9 had some issues with the D9H model chewing up a few final drives during its career.
Thu, Dec 29, 2011 1:41 PM
hicrop10
Hi, Boots.
We had one of those aminals.They were way to slow to push the scrapers with,so we left that to the D9's to.When it came to ripping out rock and feeding the loaders it was perfect.It went from one rock job to another without any major problems,the problem did start once we took the aminal from the jungle.We took a job in the city of Phila.we were to remove about 1,000,000cy of burnt trash and haul it over to the landfills of New Jersey.we also had about 1,000,000cy of river muck we had to remove,we used our draglines to cast it to the big dozers and they pushed it to where the loaders could load it out.This is where we lost the final drives in the HD-41 and no sooner did we fixed that then the motor swallowed a valve.I can still hear my father yelling to get that beast back in the jungle,once it made it way back to the rock piles of upstate PA it work fine.Mike Durkin
Fri, Dec 30, 2011 8:07 AM
