Open Center or Closed
1S1K
Send a private message to 1S1K
Hi All,
Can someone tell me how to tell the difference between an open center and closed center hydraulic system, My D4 Cat has an aftermarket pump and valve that are pretty old and I can't easily tell what the pump is. The problem is that the float position on the valve is worn out and its leaking. Also it only has 2 remotes to control the blade and I would like a third so I can run my disc at the rear without unhooking my blade controls. Also, is there a way to figure out how many GPM the system is so I can properly size the new valve? Thanks for the help.
1S1k
Tue, Feb 10, 2015 10:24 PM
Open center hydraulics is pretty much the norm. Easiest solution is to change out your two section valve for a three section and not worry about pump gpm. Prince hydraulics sell an assortment of universal valves for this type application and you can get change parts for detent or spring return spools.
Tue, Feb 10, 2015 11:16 PM
jdierking
Send a private message to jdierking
From another website:
[indent]Q: What is a closed center or open center valve?
A: Open center refers to valves that allow oil to circulate at low pressure through the valve and back to the tank or reservoir when the valve is in the neutral position. Open center systems are normally used with a gear pumps…aka…if the engine is running, it is pumping oil. Closed center refers to valves that do not allow oil to flow through the valve when the spools are in the neutral position. The flow path is dead headed at the valve. Closed center systems are normally used with piston pumps or pressure compensated pumps. [/indent]
You can determine the flow by looking at the pump. It may have a tag or you may have to measure it. Like was said before, you can also go off the current valve and get something with similar sized ports and spools and you should be fine.
Also pay attention to where the relief valve is in the system. If it is in the current valve be sure your new valve has one as well and that it is set properly or you can destroy other parts of the system.
Tue, Feb 10, 2015 11:39 PM
cojhl2
Reply to jdierking:
[quote="jdierking"]From another website:
Also pay attention to where the relief valve is in the system. If it is in the current valve be sure your new valve has one as well and that it is set properly or you can destroy other parts of the system.[/quote]
Like what happened to a friend of mine on his 580K. Somehow they got the system (it was borrowed) incorrectly put together and broke the crankshaft. (gear pump, positive displacement)
It's a long story!!
Wed, Feb 11, 2015 6:30 AM
