One wore out belt pulley
Showing 1 to 7 of 7 results
YeLLoIrOn
Send a private message to YeLLoIrOn
Cat 22 that seen better days. It at one time had a homemade cable blade on it.
Check out the part # on the belt pulley though. Its special edition!😄 😮
The tractor is suprisingly straight considering its as busted up as it is. The left track frame is broke and been welded in 10 places that i can see! Some one really like burning welding rod around this one.
[img]http://i26.photobucket.com/albums/c148/blky2k2z/IMG_0957.jpg[/img]
[img]http://i26.photobucket.com/albums/c148/blky2k2z/IMG_0956.jpg[/img]
[img]http://i26.photobucket.com/albums/c148/blky2k2z/IMG_0959.jpg[/img]
Mon, Feb 15, 2010 11:28 AM
Orchard22
Send a private message to Orchard22
nice find is it for sale? if so for parts or not?😕 i would really like those engine and grille gaurds and the precleaner the aircleaner bottom and holding arms.😊
if you are keeping it though nice to see it's not out there rotting away and got saved😄
1935 Caterpillar
Twenty-Two Citrus(or low top seat orchard)
serial number:2F2204
Mon, Feb 15, 2010 10:58 PM
ronm
Reply to Orchard22:
I've seen a lot of worn-out stuff in 40 years, but that wear pattern on that pulley is about the coolest....😎
Tue, Feb 16, 2010 9:49 AM
Sasquatch
Thank you received: 5
Reply to ronm:
Yeah, that pulley is cool enough to hang on the wall. Call it a "conversation piece".😄
Tue, Feb 16, 2010 10:12 AM
cojhl2
Reply to Sasquatch:
That fan looks like it runs backward.
Tue, Feb 16, 2010 11:39 AM
Art From De Leon
Send a private message to Art From De Leon
Reply to cojhl2:
Are the remains of the part numbers that were cast into the pulley casting the shadows?
Tue, Feb 16, 2010 8:55 PM
SSsssteamer
Send a private message to SSsssteamer
Reply to Art From De Leon:
This old Cat had a home made blade on it in the past. In bull dozing burning stump/slash piles, it is a common practice to install a reverse fan blade that pushes rather than pulls. The reverse blade keeps the smoke, flames and dirt out of the radiator and away from the operator. I have seen several Cat fan blades that the pitch of the blades can be quickly reversed with the twist of a spanner wrench.
Wed, Feb 17, 2010 1:00 AM
Thank you received: 95
Reply to SSsssteamer:
at a glance that appears to be a standard fan put on backwards---they are not very efficient pumpers like this and doing this has been found to be the cause of many overheat problems.
BUT! you make do with what ya got to get the job done and try and overcome trash buildup in the core (and operators eyes) in the application cited above.
Wed, Feb 17, 2010 6:16 AM
