Old Magnet Comments On Cat D5B
Showing 1 to 10 of 16 results
Dick Tucker_archive
Send a private message to Dick Tucker_archive
I found a Cat D5B for sale not sure what year model it is the seller thinks it is 1985 or 1986. Here are some pictures including the nameplate. Any comments good or bad on this model Cat?
Thu, Apr 20, 2017 2:59 AM
Good unit as far as I know. Do hear some rumblings about fail safe parking brake malfunctions.
3306 direct fuel injection and 105 hp. I've got one source that says it's a 1983 model and another that says 1984.
Looks pretty clean from the one picture.
Thu, Apr 20, 2017 3:57 AM
Dick Tucker_archive
What is the fail safe parking brake? Also from the picture I would not tell much about the undercarriage condition looks like it doesn't have much adjustment left. Owner says it has 3000 hrs on the hour meter I doubt that the hours are correct? Comes with the straight blade and angle blade they are asking $25,500.
Thu, Apr 20, 2017 4:16 AM
rturn3060
Send a private message to rturn3060
Reply to Dick Tucker_archive:
If I am not mistaken the 5 has the same track chain as a 4 which would stretch earlier than other models. With regards to value check the Machinery Trader web site. There is currently 38 shown under auction results which will give you a range of prices. There is also about 30 listing of dealer tractors for sale.
Thu, Apr 20, 2017 5:06 AM
Reply to rturn3060:
Not so!!! D4 is 6.75" pitch track, D5B is 6.91" pitch.
Some units have gone to an emergency/fail-safe & parking brake that uses a spring applied fail safe brake piston which is held off by hydraulic system hold off pressure. Locks up the brakes if there is a system failure.
The parking brake can also be manually set.
Can be an issue when towing.
Seems the system can be temperamental.
Thu, Apr 20, 2017 6:52 AM
captainhowdy
Send a private message to captainhowdy
i used to run one just like that. it had a powershift and was a gutless wonder. the older model J model was a more productive machine by far. i don't remember a failsafe brake on mine. the narrow gauge D5B was better because of the 8 foot blade.
Thu, Apr 20, 2017 9:55 AM
rturn3060
Reply to captainhowdy:
Old Magnet, I stand corrected on pitch
Thu, Apr 20, 2017 10:06 AM
Reply to rturn3060:
Looks like the fail-safe brake came in at s/n 25X02073.
For sure it's not going to be as snappy as a later 3306T 140hp in the D6's
The 94J, 95J, 96J earlier models got up to 105 hp N/A same as the D5B's.
Thu, Apr 20, 2017 12:02 PM
Dick Tucker_archive
Old Magnet when I get a chance to look at this machine what are the dimensions for track ware? What problem areas should I be looking at? How can I be sure the Power Shift Transmission is ok?
Thu, Apr 20, 2017 10:49 PM
That unit should have sealed and lubricated track link #3P7153/4.
Sealed and lubricated track pitch is not normally measured due to the absence of conventional internal wear. Individual joints should be inspected for lubricant loss by hand feeling for warm bushings. Individual dry joints can be measured to determine pitch extension due to internal wear. Section length should not exceed 7.50"
Rail height is 4.06" new, 3.69" @ 100% worn.
Other than running pressure checks on the power shift transmission the only way to check it out is to run it though its paces.
Thu, Apr 20, 2017 11:30 PM
Dick Tucker_archive
Old Magnet you mean run power shift transmission thru its paces like try all of the forward & reverse gears and load the machine to the point to see if it will spin the tracks? What about checking fluids like final drives. Also would probably be a good idea to see how much blow by the engine has while running.
Fri, Apr 21, 2017 2:29 AM
