Old Magnet Comments on 2008 Cat D4KXL
Showing 1 to 10 of 27 results
Dick Tucker_archive
Send a private message to Dick Tucker_archive
Old Magnet looking at possible purchase of Cat D4KXL. I assume this is a hydrostat machine. Do you know of any problems with this model? Here is a picture of it.
Wed, May 3, 2017 9:15 PM
Yes, it is a hydrostat machine.
Too new for me to know anything about. Here's some specs.
http://www.ritchiespecs.com/specification?type=Constructio&category=Crawler+Tractor&make=Caterpillar&model=D4K+XL&modelid=90509
Wed, May 3, 2017 10:23 PM
ironman3406
Chapter Twenty Seven
Send a private message to ironman3406
I haven't heard of much issue with these tractors - everything always comes down to hours, history of machine, abuse etc. Do you have the serial number of it I could look up the repair history of it for you on the Cat side of things.
Thu, May 4, 2017 5:21 AM
Dick Tucker_archive
Reply to ironman3406:
Ironman I will try to get the serial number, repair history would tell me a lot, Thanks
Thu, May 4, 2017 9:04 PM
Dick Tucker_archive
Reply to Dick Tucker_archive:
Ironman here is a photo of the model & serial number plate but unfortunately I cannot make out the serial number. Called the owner and he did not have the serial number written down. Is it somewhere else on the machine?
Tue, May 9, 2017 7:54 PM
d9gdon
Dick Tucker,
Your serial number is MMM00353 and that tractor was built on 5-19-2008.
Tue, May 9, 2017 9:33 PM
Dick Tucker_archive
Reply to d9gdon:
Dick Tucker,
d9gdon wonder if there are any recall notices from CAT on it. I thought the serial number was below MMM00353?
Tue, May 9, 2017 10:48 PM
Dick Tucker_archive
They are asking $72,000 for it has around 2,300 hrs and they say it has 70% rails left. Here are 2 pictures of it. I found past sales in Ritchie Brothers around $62,000 for a machine just like it. What do Yall think? It comes with a mesquite tree grubber and brush rack.
Tue, May 9, 2017 11:26 PM
There's always "asking" and "getting". Probably not far out of line if you add in the attachments.
Start negotiating at the $62K.
Some questions:
What is the current type owner? private, rental company, construction company, lease, dealer? etc.
Tue, May 9, 2017 11:57 PM
d9gdon
Some questions:
That red sand that it's in will eat an undercarriage up. Have somebody that knows what they're doing to measure it instead of accepting a guess from the seller. I'm not sure how familiar you are with dozers, but you can get over $10 thousand just in parts tied up in a new undercarriage, even on a small dozer like that.
It looks like a well cared for machine from what I can tell from the pictures. I've put probably 3-400 hours on the D6K's and the worst thing about them is the stupid thumb wheel to angle the blade. I had to wear a glove after the first day from a blister.
I looked up your serial number to get the build date, so I know that MMM00350 is correct.
Wed, May 10, 2017 12:19 AM
ironman3406
Reply to d9gdon:
I PM'ed you with some additional information on the machine - being it has 2300 hours I don't think the price is that terrible - I watch the auctions pretty close and 4000 - 8000 hour D4K's have been making $40,000 - $65,000 USD some has rippers or winches some just had a drawbar, some were LGP's - so as low hours as it is, and with the attachments they are offering with it, I don't think its terrible - Does it come with the ripper, the original build records show that it had a drawbar so they must have added the ripper to it after the original purchase, so there is added value if it comes with the ripper - I would however reach out to the local Cat dealer and have them measure the undercarriage so that you have the real data of where it is at - it could scale your offer depending where it is at - it is system one undercarriage on it which wears more equal and lasts longer than SALT undercarriage, but its not cheap to replace either if it is worn to bad. I would be shocked if the undercarriage is badly worn though, I know guys that have 6000-8000 hours on system one, on D6T's and D8T's, it all depends on soil abrasion. Hope this helps a bit.
Wed, May 10, 2017 2:06 AM
