Old D6 Dozer Weight ???
Showing 1 to 10 of 20 results
Xtremist
Send a private message to Xtremist
does anyone have reliable info on how much these old D6 9U cats weigh ? I found (what i think) is a crazy good deal on a running one and a parts cat that goes with it and id like to pick them up, but they are 5+ hours away from me and id like to know if i can haul both of them together on my lowboy legally or not.... the runner has a winch, the non runner is missing the blade, c-frame and upper part of the engine. thanks for the insight.
Sat, Dec 5, 2020 11:57 AM
wimmera farmer
Thank you received: 7
Around 40000 lbs the pair. Can't see the rear winch could be 2000 lbs there.
Sat, Dec 5, 2020 5:29 PM
Thank you received: 50
Reply to wimmera farmer:
Here's some weights to work with..
9U (dry & bare) = 17,520 lbs
6A blade = 4,430 lbs
D6N winch = 1,635 lbs (w/o cable)
#46 Hydraulic control = 585 lbs
Empty cylinder head = 160 lbs
Sat, Dec 5, 2020 11:59 PM
Thank you received: 48
Bare tractor just under 19,000 pounds by the book. Track guards, brush cage, hard nose, hydraulics, and blade are all extra.
Sun, Dec 6, 2020 12:02 AM
Reply to Ray54:
By what book? mines out of the parts book.
Sun, Dec 6, 2020 12:40 AM
I had two 9U's delivered from half way across NY state---one complete with blade and rops and the other a bare carcass--hauler said he had to take back roads as he was overweight--he didn't have an R permit so that means he could only haul 80,000 lbs legally
[attachment=61373]20151202_114827.jpg[/attachment]
Sun, Dec 6, 2020 1:50 AM
Sorry about that I had not seen your post when I posted mine. I was working off memory which is getting more suspects all the time. The book I was thinking of was a Cat Production Handbook about 1970 that had HP and weight spec from the Rd's to what was current. And I made the mistake of loaning the book out, and is now lost like my memory.
Mon, Dec 7, 2020 2:41 AM
Xtremist
Reply to dpendzic:
id like to see more pics of that 9u that you have, looks like it has a different hood ? i like the look of what i can see.
unfortunately i think that im going to be over weight so now i have to decide if i chance it or make two trips....ill call the scale house tomorrow but i dont think that i can permit it because its a divisible load which sucks...
Mon, Dec 7, 2020 9:17 AM
The hood was modified for a turbo
[attachment=61395]D6 007.JPG[/attachment] [attachment=61396]D6 009.JPG[/attachment]
Tue, Dec 8, 2020 2:27 AM
Vance Nickerson
Send a private message to Vance Nickerson
Reply to dpendzic:
Two trips suck it up unfortunately.
Tue, Dec 8, 2020 4:54 AM
Xtremist
Reply to dpendzic:
Im a bit confused, do you mean his max gross weight couldnt be over 80 000 lbs ? Because theres no way those 2 weighed more then 80k by themselves. Im going to call the scale tomorrow but i THINK my gross can be 103000 lbs and my rig weighs about 52000 which should mean ive got 51000 payload. But i need to check those numbers with a DOT officer...
[quote="dpendzic" post=224154]I had two 9U's delivered from half way across NY state---one complete with blade and rops and the other a bare carcass--hauler said he had to take back roads as he was overweight--he didn't have an R permit so that means he could only haul 80,000 lbs legally
[attachment=61373]20151202_114827.jpg[/attachment][/quote]
Thu, Dec 10, 2020 11:04 AM
