Hi, Bradsmack.
Yer jest nevva know wutz hidin' in them thar woods, do yer?
Thanks for sharing. When is the rescue mission starting?
Lot of iron just parked and rusting---wonder what happened.
BullDozerBob
Spokane Wa.
wow that some nice little find there you could go building roads all you need is a little fuel.
on second thought, there weighting for the Restoration shop to be finished in the background then there will all be going in for overhauls. the one cat looks to have good pads on it.
I that is not the truth, then you SE members need to getting after those rusting gems! Wish they were around here!
G
Sure wish they were closer to me.
I believe I could make them run again.
I likes a challenge !:biggrin1:
Interesting you got that close. Here in Tasmania you would be shot before you got into camera range over a haul like that. It's probably worth over 100k here on current cat values😊
