old cat 12 grader
old cat 12 grader
Showing 1 to 10 of 11 results
andyindy
Send a private message to andyindy
Going to look at a older cat 12 grader, pony start. Supposedly in usable shape, both motors run good, plus add on power steering, no cab, he also has a kit to make direct start. Havent got serial # yet. Any thing in particular to look at? Any problem areas? Thoughts?
Thanks, Andy.
Cat D8K, Cat112 3u grader, Cat 236 skid loader, JD 690 B hoe, Case (Can't Afford Something Else) 1150b, 450 dozer, 450 loader, 580c backhoe x2, 310f loader backhoe, Mack R model tractor w/ Rogers RGN My fleet of mostly working antiques. :crazy😛roviding a great living for the parts guys! :eyebrows:
Sat, Jul 23, 2016 2:03 AM
mog5858
have a good little read on this. link he said it better than i can. there was a theread going about a 212 that had lost of grader info just the othere day.
http://www.acmoc.org/bb/showthread.php?20409-Cat-12-Graders-Pre-G-series
Sat, Jul 23, 2016 5:03 AM
andyindy
Reply to mog5858:
Thanks for the heads up! Good info in it, thanks, Andy.
Sat, Jul 23, 2016 5:31 AM
chuckb
Reply to andyindy:
Is this the one on cincinatti craigs list for 3500 i would buy that in a heartbeat if i had some loose cash looked like about new tires and very clean
Sat, Jul 23, 2016 5:42 AM
andyindy
Reply to chuckb:
Thats it! He has sent serial #, 3u 187.From what I can find on this site, that makes it a 112 ? Pretty early production I guess. Any idea what year?
ANDY
Sat, Jul 23, 2016 8:10 AM
old-iron-habit
Reply to andyindy:
ANDY
[quote="andyindy"]Thats it! He has sent serial #, 3u 187.From what I can find on this site, that makes it a 112 ? Pretty early production I guess. Any idea what year?
ANDY[/quote]
If its a 112 and you decide you don't want it, let me know. Might be a little small for you. You probably really need a 12. Big Grin
Sat, Jul 23, 2016 9:26 AM
3u187 is a 1947. First year with the D315 engine
Sat, Jul 23, 2016 10:13 AM
andyindy
Well, I got it bought this evening!!:loco I'll try and post some pics when i get it home, prob this week end. Pretty happy with it, 69 years new!! Engine & frame serial #'s match! Showing 1500+ hours, could this possibly be right? Probably not....but still seems to be in good shape! Parts book on the way, Ebay. First order of business, brakes. Cat dealer can still get the brake parts, who else can supply parts for a 69 year old machine? NOBODY!!!!!!GO CATERPILLAR!!!!
Tue, Jul 26, 2016 9:21 AM
andyindy
Reply to andyindy:
Got the old girl home, real happy with it. Sheared the pin on the front leaning wheel, last owner tack welded coupling, now it let go. How hard a pin does it take? Added brake fluid and right side is working, looks to have been rebuilt. Notes the mechanic kept said couldn't get left wheel off to work on brake. Put new belt on power steering and it works OK when your moving. Bought a operators and a parts book off E bay. Still needing a servicemans book for 112 3U #187. Any one have one? Trying to post pictures, but not having much luck yet.
Andy..
Fri, Aug 5, 2016 3:26 AM
oldbeek
Reply to andyindy:
Andy..
just bought a cat 12 8t6995. Do not know nothing about it. Where on e-bay did you find manuals? It was being towed to start. I got the poney motor running but it is missing the clutch and drive assy that is between the pony and main engine. New to this, any help appreciated.
Tue, Aug 9, 2016 11:40 AM
rmyram
pretty much any clutch/pinion assembly off a d318 will work for you,
Tue, Aug 9, 2016 12:08 PM
