Old 955K engine
Old 955K engine
Showing 1 to 10 of 31 results
driggars
Send a private message to driggars
can someone tell me the model number of the engines are in old cat 955K track loaders?
I have been looking for a parts manual for one.
Clint D
Wed, Jan 24, 2007 10:42 AM
Thank you received: 39
I believe the entire 955k series used the D330T engine. The US production being 115hp.
Wed, Jan 24, 2007 11:04 AM
driggars
Thanks, do you know where I might find a parts manual for it?
Clint
Wed, Jan 24, 2007 11:24 AM
84WD10
Send a private message to 84WD10
Hello Driggars,
I note that you are asking what "CAT" engine the old "955" traxcavators used, the first model "955" traxcavator, Series "12A" used the "D315" engine, which was basically the same engine used in the 7U Series "D4" with a H.P. increase. I beleive that the next "955" 60A Series used the then new engine , the "D330" turbocharged engine.
The first ever "CAT" built Traxcavator, the model No 6 Shovel which was built on a redesigned "9U" Series "D6" tractor chassis with many major changes, this tractor the Series "10A" was followed by the "12A", then the "955".
If you can give the exact model, then the exact engine data can be given.
Sincere regards
Alan T. Lewis
Christchurch
NEW ZEALAND
Wed, Jan 24, 2007 11:34 AM
Reply to driggars:
Clint
You can get them from Cat Legendary Literature Services
http://www.cat.com/cda/layout?m=90800&x=7
The Cat stuff is excellent repro but pricey. At least check the list for the correct form number for the manual then you could also check ebay and ebay vendors.
They made a lot of different models of the 955K.
Avoid the "Jensales" repros, they are very poor copies.
Wed, Jan 24, 2007 11:44 AM
driggars
Alan
The only numbers that are recognizable is a serial number on the engine, which is the same as the tractor ser#
61H1659
Clint
Wed, Jan 24, 2007 12:28 PM
rusted
Send a private message to rusted
Reply to driggars:
Alan
61H1659
Clint
Clint, OM's info is correct...the 955K is powered by the D330T. As far as a parts manual is concerned the ebay advice is also good...there weren't many 61H series machines built, but a parts manual for 48H, 53H, or 31J would also be suitable as they are listed as equivalent to 61H in Cat literature.
Wed, Jan 24, 2007 3:28 PM
driggars
Reply to rusted:
Rusted
thanks! that is just what I need, a confirmation. I to found out last night that there were not many references to the 61H series , seen lots of 60A, but I was thinking the 60A was closer to matching the 955H series.
I see some D330 manuals on ebey but no D330T's I would assume the D330 didnt have a turbo?
Clint
Wed, Jan 24, 2007 10:31 PM
driggars
Reply to driggars:
Rusted
Clint
OK, thanks for the help so far, now I have one more question if someone can answer. I need to know the head bolt torque setting for this motor? anyone know?
Clint
Thu, Jan 25, 2007 3:15 AM
Reply to driggars:
Clint
From the 955 60A1-up Service Manual for the D330T
Thu, Jan 25, 2007 3:40 AM
driggars
OLD MAGNET
thanks so much, and quick! I take bacl everything I ever said bad abot you, 😉 Just kidding.
That is exactly what I needed
Clint
Thu, Jan 25, 2007 3:45 AM
