oil seal
railroadjoe220
Send a private message to railroadjoe220
I have a D47j2096w , I need the front crank shaft seal for it.Cat says its been discontinued.Does anyone know the no. for this seal through a bearing supplier?I asked for aquote on piston rings & they were $556.Rod bearins were $388 for 1 rod. Wont be rebuilding it at thouse prices.
Thanks Joe
Wed, Jan 27, 2010 6:25 AM
Willie
Joe you need to check with F.P.Smith in Fairfield CA. http://www.fpsmitheq.com/ or Florin Tractor in Sacramento CA and I think Mike has the web address up in the sticky section
Wed, Jan 27, 2010 7:10 AM
Thank you received: 60
Reply to Willie:
Front crankshaft seal is a Cat 1B2256 which interchanges to a CR 21336.
Wed, Jan 27, 2010 8:33 AM
| Kingaroy, Queensland
