Oil PSI on 2 Ton
Oil PSI on 2 Ton
jthornton
Send a private message to jthornton
Does anybody know what the oil PSI should be on 2 ton? Thanks!😄
Fri, Feb 13, 2009 10:12 AM
OzDozer
The book only states, "in excess of 12 psi".
Fri, Feb 13, 2009 8:46 PM
Mike Meyer
Thank you received: 6
Reply to OzDozer:
I just put a brand new oil guage on my 2 Ton as the original guage was hard to read when I was plowing on my farm, at idle it reads 32 pounds, with the engine flat out it is 38 pounds. I run Shell "Older Engines" oil in mine, it's like 25/60 weight.
Hope that helps
Mike
Sun, Feb 15, 2009 5:34 AM
