Oil pan removal on RD7-pictures
Tractor-Doctor
Send a private message to Tractor-Doctor
[attachment=33213]IMG_20160120_174805.jpg[/attachment][attachment=33214]IMG_20160120_174720.jpg[/attachment][attachment=33215]IMG_20160119_173612.jpg[/attachment][attachment=33216]IMG_20160119_173438.jpg[/attachment]Here are some pictures of how I ended up getting the oil pan off my RD7 using the advise from WyoCat. In the pictures I haven't installed the second safety strut I made for both sides. I made the struts out of 2 1/2 X 2 1/2 X 1/2 inch angle iron welded to a 1/2 X 3 inch plate. Then bolted them to the frame with 5/8 grade 8 bolts and nuts. The support on the front of the machine is 3 X 3 X 1/4 tubing supported by the oak blocks. For future reference I raised the front end about 48 inches and the radiator is just about a 1/2 inch away from the Letourneau blade support. The oil pump will just clear out of the bottom of the block which will then allow you to remove the oil pan.
Jim
Thu, Jan 21, 2016 6:01 AM
seiscat
Attachments did not work
Thu, Jan 21, 2016 6:16 AM
Tractor-Doctor
Reply to seiscat:
I loaded them again.
Thu, Jan 21, 2016 6:27 AM
seiscat
Reply to Tractor-Doctor:
[attachment=33218]173438 90.jpg[/attachment] [attachment=33219]173612 90.jpg[/attachment] [attachment=33220]174720 90.jpg[/attachment] [attachment=33221]174805 90.jpg[/attachment]
Good job. Sturdy cribbing and good safety supports. Close clearances overcome. Thanks for posting this. You have a very nice and clean shop.
Thu, Jan 21, 2016 6:58 AM
Tractor-Doctor
Reply to seiscat:
Thanks for the complement.
Jim
Thu, Jan 21, 2016 8:54 AM
WyoCat
Jim
Good job Jim! Glad you were able to get it lifted up enough to get the pump out. Thanks for posting pictures.
Chad Enyeart
Thu, Jan 21, 2016 9:20 AM
