Oil on brakes
Oil on brakes
bullet4x4
Send a private message to bullet4x4
I finally got my newly aquired it was advertised as a D46u but it turns out to be a 7U it's a great little machine but after 3 hours of very hard work clearing thick scrub in steep rocky country the brakes became less effective both inspection covers are missing and I noticed both brakes covered in oil Im wondering if this is common and a big job to fix? It has sat for a long time and has no damage so I'm guessing up until now it's had a easy life
Tue, Jun 12, 2012 5:27 PM
ol Grump
The first thing I'd do would be to remove the drain plugs at the bottom of the steering clutch/brake compartments and see what comes out. Let 'em drain, replace the plugs and fill the compartments to the a little above the bottom of the brake bands with diesel or kerosene. Run it back and forth a bit w/o using the steering clutches to wash the bands and drums, tap the brakes a few times and drain again. Then run it back and forth some more while riding the brake gently to dry 'em out. Run the critter some more after replacing the drain plugs and see if you can find where the oil is coming from. A good place to see is after you remove the two inspection plates at the back of the tranny behind the steering clutch/brake compartments.
Tue, Jun 12, 2012 9:12 PM
callan
Send a private message to callan
Reply to ol Grump:
thats definately a good start.
might be worth checking your transmission oil to see if its dropped at all as well.
you say you were clearing in steep country so theres a chance oil was weeping through the diff axle seals.
the other spoit the oil can come through is from the final drives, so it might be worth popping off the hex bungs on either side at the rear
of the dozer. they are the oil fill points for the final drives.
Wed, Jun 13, 2012 11:34 AM
bullet4x4
Reply to callan:
The oil seem to be only on the linings themselves the backing plates are dry and there doesn't seem to be oil anywhere else in there when it's cold or you stop for five the brakes work well but when you work it for a while they get worse
Thu, Jun 14, 2012 1:40 AM
lil cat mec
Send a private message to lil cat mec
Reply to bullet4x4:
if it was only in the pads i would think as you work it it would get better not worse:/ i would go with ol grumps ideas!
my .02
1935 CAT 22 2F4455W
1990 CAT D6H 4GG04120
2012 CAT 272C RED02823
1971? CAT 951B 86J01212
Thu, Jun 14, 2012 2:51 AM
