oil leak D6 9U
oil leak D6 9U
HOLLANDCAT
Send a private message to HOLLANDCAT
I have a oil leak between the engine block and the fly wheel housing from a D6 9U23008.
The oil level in the clutch was a bit high, so i let that out.
Stil is leaking now.
If i take out the clutch and the flywheel , is there a seal ??
I have no book for this serial number , and not sure if there is a seal ?
Or the bearings from the main engine are bad ?
Who can help on this ?
Thank you , Gilbert
Tue, Nov 28, 2017 12:55 AM
There normally is no crankshaft seal. Depends on bearing fit and screw thread feature to direct oil back to the sump.
There is however a rather involved retrofit seal system that Cat supplied later.
Tue, Nov 28, 2017 2:01 AM
HOLLANDCAT
Hello Old Magnet ,
Is there more information from this retrofit seal ?
Or could the oil come from the oil cluch ?
Thank you , Gilbert
Tue, Nov 28, 2017 3:42 AM
Reply to HOLLANDCAT:
Hello Old Magnet ,
Thank you , Gilbert
Here is the seal information....
Tue, Nov 28, 2017 6:26 AM
A leak between the block and flywheel housing is more likely a gasket problem.
The crankshaft seal is primarily to prevent oil transfer from the engine to the oil clutch housing.
Tue, Nov 28, 2017 7:20 AM
mcd9
Send a private message to mcd9
I had a bad oil leak like yours on my d6b. The pin that supports equliser spring craked the cross member, and the cross member sheared off two rear pan bolts. Had to rebuild the cross member and make a new pin.
Wed, Nov 29, 2017 12:50 AM
Reply to mcd9:
The 8/9U doesn't have and equalizer spring pivot pin. Leaf spring is seated in its own cross member saddle.
Wed, Nov 29, 2017 2:06 AM
u-joint
Send a private message to u-joint
gilbert,
god called and said you were here! if you want to know what your oil issue is give me a call. otherwise good luck with the information here!
Wed, Nov 29, 2017 10:50 AM
HOLLANDCAT
Hello Pete ,
I did not know this either , that he had a call .
Could ask other questions also ? Haha
Gilbert
Fri, Dec 1, 2017 3:49 AM
