Oil cooler
Oil cooler
Flathead
Send a private message to Flathead
I have three Caterpillars. Two have the oil cooler lines removed and plugged another has a short bypass made. It looks like there should be a loop at least back to the filter base.  Which is correct?
Sun, Mar 7, 2021 1:39 AM
Thank you received: 78
Both, so long as the ones that are plugged also have the relief valve and spring removed
Sun, Mar 7, 2021 6:45 AM
Flathead
Thank you Neil. 👍🏼
Sun, Mar 7, 2021 7:28 AM
