Oil clutch gaining oil
Showing 1 to 10 of 34 results
Norm R2,22
Send a private message to Norm R2,22
I've been looking at a D4 7U with an oil clutch. The fellow selling it says it has just started to get engine oil in the clutch. After about three hours of running it had gained about a gallon of oil. It is about 8" above the full mark on the dip stick. In checking with some of the local folk I get opinions of, the breather is plugged to there is a crack in the partition between the engine and the clutch compartment. I figured I'd see what the brain trust here had to say before I make any kind of offer. The pony and main run well. Oil pressure is in the middle of the safe range (even though he has been running 15-40 oil). There are the usual things that need fixing on a 1957 machine but the oil business has me worried.
Fri, Nov 6, 2015 4:09 AM
Willowhic
Send a private message to Willowhic
Sounds like a leaking rear main seal.
1988 JCB 1400B backhoe
1966 Cat D9 cable dozer
1966 Cat 980 wheel loader
1967 Galion 140 grader
1963 Cat D7E hydraulic dozer 47A886
196? Cat 112 grader 3U3308 (engine: 3U243)
Fri, Nov 6, 2015 5:52 AM
old-iron-habit
Reply to Willowhic:
Don't believe you will find a seal in it. It has a slinger that keeps the oil in the engine. Can leak when shut off if left on a slope with the front up.
Fri, Nov 6, 2015 6:53 AM
Thank you received: 77
Reply to old-iron-habit:
Norm, definitely check the breather situation because that's the easiest fix. Clean it out (or even take it off and replace with a temporary open pipe and give it another run.
Fri, Nov 6, 2015 7:34 AM
Norm R2,22
The clutch won't snap over and sometimes it won't let the transmission in or out of gear. I think that is a matter of adjustment or the friction material has swollen. I can't figure why the oil level in the clutch would get so high without draining back into the engine. Is there a pump for the clutch or is it a "Splash" system? I don't have the D4, it is for sale and this is the debate I'm having with myself as to should I buy it.
Fri, Nov 6, 2015 10:28 AM
Reply to Norm R2,22:
The oil clutch has its own circulating pump. If it won't snap over center it is either out of adjustment or the clutch plates are stuck. If it's gaining oil it's either due to high pressure in the main engine sump due to blow by, clogged vent or worn main bearings. There is no rear seal, just a reverse corkscrew thread on the crankshaft to pull oil back into the sump.
Fri, Nov 6, 2015 11:04 AM
Willowhic
Thanks to O M and O I H for setting me straight about the seal. My D7E was gaining oil in the clutch and is designed with the same reverse-rotation auger machined into the rear main journal; the problem with mine was due to its seal. But where there is no seal, the guys are correct: wear in the rear main and excessive crankcase pressures are the most likely causes for oil to migrate from the engine to the oil clutch housing.
As to the question of purchasing the machine, I'd still get it if the UC was decent enough and wouldn't let the oil issue hinder the purchase.
Cheers
Fri, Nov 6, 2015 5:40 PM
Lance Jones
Reply to Willowhic:
Cheers
My First Cat was a very late 7U 43600 odd serial No and it developed this Problem, Sometimes I carried a Small pump to transfer Oil back . I found out that there was Lip seal that Could be Fitted as these were fitted to Grader Motors apparently , That was 35 years ago , was a fair amount of Work to fit it in , Recall having to drill a drain Hole in Front of seal . The dealer got that Seal from Singapore Depot I well remember . It did not stop it Leaking Completely ,but made it Quite manageable .I can't recall about Breather though ,I was only a learner Bush Mechanic in Those days [Still am !!] That tractor had the 2 Speed Reverse Option in it . bearings may have had some wear to allow this too happen also . LJ
Sat, Nov 7, 2015 12:49 AM
Norm R2,22
Reply to Lance Jones:
It would seem that the opinion is to get this tractor even with the problems it has. It is a package deal. The D4 with the problems also has a Hyster winch so that is a plus. The second part is there is a well worn loader (933) with worn tracks and a bad main (connecting rod?) but a good pony, a dry clutch and the loader part shot included for $3K. The two machine's serial numbers are about nine digits apart. I am running out of places to put machines so if I go for the deal the parts machine will have to go.
Sat, Nov 7, 2015 1:19 AM
Norm, is that the D4 parked up between Ithaca and Whitney Pt?
Sat, Nov 7, 2015 1:32 AM
I suggested to another person that had the same problem that it might be possible to simply let the oil clutch overflow back to the engine crankcase. This same basic setup was designed into the late 8T, 70/71D and 99E graders. The engine oil pump had a separate section to feed the clutch on the 99E, not sure on the earlier models, but the engine and clutch shared the same oil and filters.
Just need some kind of connection to let it flow back before it gets high enough in the clutch to cause trouble.
Sat, Nov 7, 2015 2:11 AM
