Oil Capacities for D8 13A
gasengin
Send a private message to gasengin
Just got my new (to me) D8 13A home. Need the oil capacities (oil, antifreeze, ect.) for this machine. I got a book with the Cat, but it is missing the back cover where the capacities are printed. I am not sure if it is a 13A or a 2U. It has a 13A serial number on the engine, but I know the engine has been changed. The previous owner said it was a 1952 so would make it a 2U. Not sure if the capacities are the same for both models. Hope some one has a book with a back cover with this information. Thanks.
Sat, Jan 24, 2015 8:19 AM
wimmera farmer
Thank you received: 10
Diesel engine oil 34 quarts
Starting engine oil 2 quarts
Fuel injection pump 3/4 quart
Air cleaner diesel 5 quarts
Air cleaner starting 3/4 quart
Fuel tank 68.5 US galls
Cooling system 25 US gall
final drive 20 quarts each
transmission 41 quarts
transmission starting engine 3/4 quart
there were some changes in the 2U series above should be all 13A from my info
I assume the quarts are US measure
have fun WF
Sat, Jan 24, 2015 9:56 AM
