OFF TOPIC: MAGNETIC DRILLS
Showing 1 to 10 of 28 results
Thank you received: 71
Greetings everyone: Another "off topic" here, but it would make my CAT projects easier:
I am in the market for a magnetic drill. Do any of you have a preference? I plan on having one for boring holes in plate steel with annular cutters, holes anywhere from 1/2" to 1 1/8" on the average, and possibly an occasional 1 1/2" one.
I am going also aiming for American made. As little as I plan on using it, I still want quality.
What are your thoughts and recommendations? Aaaaaaannnd go!!!
TIA, JM.[img]/media/kunena/emoticons/lever.gif[/img]
Fri, Feb 19, 2021 1:01 AM
Thank you received: 22
I think two important factors are amount of chatter from the head, and the strength of the magnet. I don't have any American-made info for you but I bought a Chinese mag drill a couple of years ago and it did the job for me but it's definitely not professional quality. Takes a lot of prep and consideration to get it to produce a good outcome which is ok for me because I have (some) time but I'd never use it in a pro shop.
Fri, Feb 19, 2021 1:30 AM
Milwaukee with a movable/adjustable base.
https://www.ebay.com/itm/Milwaukee-Drill-Press-Electro-Magnetic-Adjustable-Position-Morse-Motor-4210-1/254868056803?epid=19031751114&hash=item3b5751eae3:g:nGsAAOSwJxBgDz4T
Fri, Feb 19, 2021 1:52 AM
I really like my Milwaukee unit with movable mag base. Bought it used several year ago and it is my go to unit for line boring drive plus making holes. Be sure to pick the right rpm capacity (two speed) units if your going big holes and cylinder honing.
Fri, Feb 19, 2021 2:39 AM
[quote="Old Magnet" post=226155"]I really like my Milwaukee unit with movable mag base. Bought it used several year ago and it is my go to unit for line boring drive plus making holes. Be sure to pick the right rpm capacity (two speed) units if your going big holes and cylinder honing.
I was wondering if we'd hear from ya! How ironic, lol
 [/quote]
Fri, Feb 19, 2021 3:27 AM
Delta KJ
Agree with the others that the Milwaukee mag drill is an excellent drill. I have used the Milwaukee and own and use the DeWalt DWE1622K mag drill and both performed very well in tough conditions.
Fri, Feb 19, 2021 3:29 AM
josh
Thank you received: 6
Reply to Delta KJ:
Another vote for the Milwaukee mag drill with the adjustable base, two speed motor and adjustable speed on the base, along with the Milwaukee Steel Hawg cutters and arbor. I use both the special arbor for the Steel Hawg cutters and the Jacobs chuck for twist drills, really nice that you can set the just the right speed for each hole size and material, and the arbor has through hole coolant capacity, with that combination the cutters last a long time and makes drilling easy, I have the 4203.
Only drawback, it's heavy.
Fri, Feb 19, 2021 8:49 AM
old-iron-habit
Reply to josh:
I've had a 3/4" chuck Milwaukee Mag drill for 30 years. I replaced the chuck a dozen years ago when it started to slip after years of abuse. I use an Yancy slugger adapter in it for the larger holes. I have drill up to 2-1/4" several times. Never had a issue or lack of power at any speed with it. It is a all steel heavy old bugger compared to todays similar models. It was $1,200.00 then and a couple years ago they were still $1,200.00.
Fri, Feb 19, 2021 10:06 AM
oilcan47
Send a private message to oilcan47
Reply to old-iron-habit:
buy a low profile one,very handle on truck frame and machinery.
Fri, Feb 19, 2021 11:36 AM
Hobo groh
Send a private message to Hobo groh
Reply to oilcan47:
We have a magnetic evolution drill, we used it for drilling out the bolts in the wing mount on the JD grader and I believe they were 5/8. I believe it is made in America if I remember. The only problem we had is if we try to dig in to fast the magnetic connection breaks and if the bit is stuck in the bolt hole it gets a bit scary. We also had broken off normal drill bits in the holes and it went though those
Fri, Feb 19, 2021 10:06 PM
Reply to Hobo groh:
Sounds like the sticking ability is common to all mag drills, not just mine : ) I used mine to drill out the lug bolts for the 2S mounts that bolt to the track frame so there was plenty of flat surface to adhere to but I wonder if wire-brushing the surface might have helped
Sat, Feb 20, 2021 3:22 AM
