Off Topic burned out exhaust ports on John Deere D head
Showing 1 to 6 of 6 results
farmerfred
Send a private message to farmerfred
I have a John Deere D with the exhaust ports burned out of or off of the cylinder head.
The attached pictures show that it is paper thin down at least 1/2". The previous owner
tried to fix it with JB Weld to no avail. The inside port on the head is good; it is just the
ones to the outside that are burned out. I don't know whether they rusted away from the
outside or burned away from the inside, or if it is a combination of both. This is a 1938
D JD, so I have a concern as to how many times the head has been hot and cooled off
and if it will accept any kind of weld or build up material.
I have inquired at Williams Cylinder Head Company in Nevada, Iowa, to see if they can
build this back up, but haven't had any response. Just wondered if anyone knows of a
way to build it back up and get a good surface on it so the exhaust manifold gaskets
will stay in? The head is in good shape otherwise, so I hate to junk it. Thanks for any
responses.
[attachment=14880]JD D Head 001.jpg[/attachment][attachment=14881]JD D Head 002.jpg[/attachment]
Fri, Sep 28, 2012 10:12 AM
rmyram
There are lot's of d's out there and a new used head should be readily available.
Fri, Sep 28, 2012 10:02 PM
cat20jd
Send a private message to cat20jd
Reply to rmyram:
Your D head is not weldable or fixable. As the previous poster said find another, can be found at several salvage yards.
Mon, Oct 1, 2012 6:54 AM
STEPHEN
Reply to cat20jd:
It might could be welded, but I concur that a used head is in order.
Mon, Oct 1, 2012 7:30 AM
chuckb
Reply to STEPHEN:
if you want to save it call Ray Shepherd in Hodgenville Ky he is an expert in cast iron repair 502 645 7444 Rays crack service
Mon, Oct 1, 2012 8:38 PM
MARCOTEN
Reply to chuckb:
if you have experiance with electric welding with rods, take the UTP8 rod (special for cast iron) and give it a try,
clean area, preheat the area you are going to weld with the torch, then after you do a 2 inch weld stop and hamer the weld just a bit for stress relief.
here some pics of a repaired hotbox:
[attachment=14940]DSC01765.jpg[/attachment][attachment=14941]DSC01770.jpg[/attachment][attachment=14943]DSC01777.jpg[/attachment][attachment=14942]DSC01814.jpg[/attachment]
Tue, Oct 2, 2012 3:26 AM
dadawg
Send a private message to dadawg
Reply to MARCOTEN:
I agree a new one is the way to go if possible. Although I rebuilt a manifold off my Fifteen with a product called pyro putty three years ago and it's still holding up very well. I personally did not think it would work, but tought what the heck i'll give it a try. Saved me a bunch of money. Google it.
Thu, Oct 4, 2012 6:26 AM
