Off Topic. Allis HD 10
Showing 1 to 10 of 14 results
old-iron-habit
I am considering purchasing a HD 10 that is on a estate. The family is selling unwanted items. It has a 4-71 Detroit in it, old 2 valve I suspect. They said they had it started but did not drive it or even try. It has been setting outside for a while, I'm not sure how long. Are the Allis crawlers prone to have stuck steering clutches like a Cat. Can these brakes and clutches be worked on without a major machine teardown. As seen driving by it is a cool looking old machine with a overhead frame Letourneau (I think) cable dozer. I will post pictures when I go look at it. Its a number of hours from here in a little hide-e-hole with some other potential toys. I would like to learn more about them before I go. I would appreciate any opinions on them and any things to look for, good and bad.
Sun, Apr 16, 2017 6:06 AM
Thank you received: 20
They did not have a real bad reputation,but had there weaknesses (final drives I think) and the clutches will stick like a Cat. They have become fairly rare since the last spike in scrape. I use to know where there were some hiding in the hills and all have gone to China now. They are similar to the early Cats you start at the outside and keep removing things until you are where you need to fix,no components.
If it works it needs saving.
Sun, Apr 16, 2017 6:54 AM
Thank you received: 41
Reply to Ray54:
Hi, O-I-H.
Around where I worked here in DowNunda, the early ones with the 'driptroit' engines hadda reputation for doing final drives. That seemed to change somewhat when A-C started using the Buda engines. They eventually bought Buda out and changed the name to Allis Chalmers. I don't know whether they changed their engineering at that time as well or if it was simply getting away from the 'driptroits' that seemed to alleviate their final drive issues. Other than that, they seemed to be a good tractor.
Sun, Apr 16, 2017 9:54 AM
Aaron
Send a private message to Aaron
Hi, O-I-H.
Buda went to Ac about 1956 or 7,I've got an HD 6 with a Buda, a few hundred more serial #'s and it would have been an AC, much better engine from what I understand, the Buda's will crack heads some what easy.
I'm familar with the HD 5's with a 2 cylinder Driptroit we have a 47 model and my 6 and they are both component tractors,I was thinking they may all have been that way.
Sun, Apr 16, 2017 10:15 AM
Headerpuncher
Send a private message to Headerpuncher
Reply to Aaron:
Nice to see a little orange blood drip over on the yellow. The older AC's with the jimmy engines were a start at reinventing the orange tractors. Their ancestors were Mogul tractors. WW 2 caused a lot of changes to be made. Engine availability and knowledge to fix them pointed to the jimmy engines. The model M, K, KO were the original AC,s The K and a bigger model not in my mind now were all converted to Jimmy's and called the HD 7-10-14-and 19. Right after WW2 the HD 5 appeared on the scene. It was a completely different design with a double reduction final drive which had two bull and pinion gears on each side thus allowing the ring and pinion , steering clutches, transmission etc. to turn twice the speed but with half the strain on the gears. This eliminated much of the final drive, transmission problems on the older models. Also a new design with engine , transmission or clutch being removable as a separate unit for ease of repair. Following that the HD9, 15 and 20 with a 4-71 and 6-71's in the 15 and 20 all with the new final design. Also their new roller design with Timken bearings and their patented roller seals Which were spring loaded mating steel on steel surfaces were the best. first they were 1000 hr. rollers and later they called them life time rollers. They were too. They had a square split block that held the roller shafts to the frame but the hole was off set so when you wore the rollers down just flip the blocks over and trim off the flanges and wear them some more. We never built up rollers , just wore them out completely.
50's AC gave up on the dripping jimmy's and bought the Buda engine. Used in the HD 6-11-16-21 an it was an improvement but not until they redesigned the heads doing away with the pre-combustion chambers, added a turbo and dry air cleaners. By then they had a tractor that was easy to work on, had plenty of power and looked kind of nice. Always said if AC had put the 3-71 in the HD-5 and lengthened the track 1 roller there might not be any yellow tractors today. Drove them most of my life and yellow ones too but always admired the AC,s for their engineering, ease to work on and looks. Working construction back in the 50's-60's it seemed if an AC turned up on the job a lot of guys thought they were a proving ground expert and would do their damnedest to find a week spot but give them a yellow one and they treated it like their baby sister.
https://www.youtube.com/watch?v=Dx8wa7JLHbs&t=101s Lots of AC tractors. First side by side dozer I ever heard of.
Sun, Apr 16, 2017 3:11 PM
mudgecko
Send a private message to mudgecko
Reply to Headerpuncher:
Headerpuncher thanks for the overview on the AC model's , good reading.
Always good to hear it from an operator's perspective that done the yards!
Oh and the bit about (they treated it like their baby sister) have seen that too!👍
Gilbert.
Sun, Apr 16, 2017 5:37 PM
Reply to mudgecko:
Gilbert.
Hi, Headerpuncher.
It's good to hear from somebody spent more time on them than I did. I only ever got to operate 1 A-C, a 'stick-shift' HD16 with a Buda 'donk' and a cable angle blade, a nice machine and man, could it climb with a loaded blade. I enjoyed operating it for the 3 months that I was on it.
As I understand it, A-C got there start in crawler tractors by buying out Monarch crawlers which also used tne name, 'Neverslip', in their early days, I suspect 'cos they bought out Neverslip. A-C began with the old Monarch models after they bought the company. These consisted of, amongst others, the Neverslip 18-30, the Monarch 50 and the Monarch 75. From what I can gather, it didn't take A-C long to change the name to A-C and introduce some new models, the M, S, K, W and L. The K and the L both had alternative models with a different diesel fuel-injected engine with lower compression than a normal diesel and with spark-assisted ignition to compensate for the lower compression ratio. These models were known as the KO and the LO but the engines were not a howling success, which apparently led to the decision to use driptroit diesels.
When they began the 'HD' line, they started with the 5, the 7 and the 10 and then introduced the HD14 which, at 130 hp, was the most powerful crawler on the market at the time, well before the 2U D8. They then went BACKWARDS from there. The next model they brought out, the HD15, was only about 115 hp. It wasn't until they brought out the HD19 with the 6-71 GM, around 10 years after the HD14, that they got back to 130 hp, followed by the HD20 which ran the 6-110 GM.
Again, as I understand it, when they began using the Buda engines, they also introduced the HD6, 11 and 16 and followed them with the 21, but I am open to 'kee-wreck-shun' on this. Then they bought out the Buda engine works and, as you said, they modified the Buda engines to deal with the head cracking and added a few refinements that made them a damned good engine. Also, as you mentioned, they brought out the 1,000 hour rollers and I think they had a torque converter model before Cat too.
In Eric Orlemann's book, "Caterpillar Chronicle", if my memory serves me rightly, Orlemann mentions that Buster Peterson built a Siamesed A-C dozer before he built the Siamesed D8s. I have often wondered since seeing that video, "A Big Job", if one or both of the Siamesed A-Cs there might have been some of Buster's handiwork. I noticed 2 different-looking Siamesed A-Cs in that video.
Sun, Apr 16, 2017 6:41 PM
Headerpuncher
Hi, Headerpuncher.
Deas. the HD 15 had a 671 but they used 60 injectors. The 20 just used bigger injectors like 90 or 100's/ I know because I had one. No need for more power because it would spin the tracks in 2nd. Needed more track and weight. The torque convertor on the 20 and 21's ran on diesel fuel and the hotter the fuel got the better they ran. They had a master clutch also and really worked good slipping up on a scraper. I ran a DW21 for an outfit that had 2 HD 20's pushing in tandem and all you had to do was just stick her in the muck and you had a load. Had to learn not to be a "Gouger".
Sun, Apr 16, 2017 7:11 PM
bryani289swmi
Send a private message to bryani289swmi
Hi, Headerpuncher.
O-I-H,
The old Allie Chalmers forum has a construction section that's pretty active, I bet you could get some information over there. Thanks.
Bryan
Sun, Apr 16, 2017 7:12 PM
old-iron-habit
Reply to bryani289swmi:
O-I-H,
Bryan
Thanks guys, lots of good information here. Headerpuncher, that was a great video of Garrison Dam. Working in North Dakota in the 70s I worked with a lot of fellows that cut there teeth on that project. I really enjoyed the stories they told. Your video gives some credibility to the stories they told. I am going to go look at the HD10 and see if I can make a deal. Like Frank and Mike on American Pickers, I'll try to bundle with some other stuff and make it a win for the owners and myself.
Mon, Apr 17, 2017 9:49 AM
Reply to old-iron-habit:
Hi, Headerpuncher.
You might like to check out this page for information on the HD20.
http://www.contractormag.co.nz/classic-machines/allis-chalmers-3/
Not wishing to 'dump' on anybody, you included, but I was always told that they had the 6-110 GM while the 15's and 19s had the 6-71.
Mon, Apr 17, 2017 11:12 AM
