O. T. - Do what yer can with what yer got.
Showing 1 to 10 of 11 results
Thank you received: 130
Hi, Folks.
O. T. - some Eastern European and elsewhere 'ingenuity' making do with what they have:
https://www.youtube.com/watch?v=w8rW0y5k-jw
Wed, Aug 23, 2023 3:36 PM
Thank you received: 54
that was part of the design of the original land rover. you could run several attachments from them.
Wed, Aug 23, 2023 5:15 PM
kittyman1
Reply to trainzkid88:
Love it, that's shade tree engineering at it's best...and most of it works...and can be further modified/improved...who knows where it goes..
- at the race track....this is called...."run what you brung" ....nice!
Fri, Aug 25, 2023 12:31 PM
Reply to kittyman1:
we have a ronaldson & tippet stationary engine at home that had a cream can for a hopper as it was either tank cooled originally or the factory cast iron one broke.
it was a common adaptation of the fergueson TE20 and ford 9n tractors to have the baby ford v8 as the original 4cyl engines were a bit anaemic in the power dept.
a mate of mine mounted a isuzu 4jb1t engine in a old fergy chassis. it now has double the hp and nearly triple the torque.
Fri, Aug 25, 2023 1:41 PM
Hi, trainzkid88.
The last farmer I worked for just after I left school had a Ford 80-donkey 6banger slotted into a Chamberlain 40K tractor and fitted it with dual rear wheels at the same time. That was quite the beast for its time.
I have done several truck re-powers, a 6V-71 Jimmy into an ACCO in place of a 6V-53 and a Cummins 903 V8 into a 1923 cab0over Benz amongst them. The Benz was good for 100 MILES PER HOUR PLUS after the re-power. I also slotted a 308 Holden V8 into an RLHC Bedford 4WD truck. That made it get up and boogie. I also put a TK Bedford cab on it and 'tilted' it while I was at it.
I also put an HB Holden Torana motor into an LJ50 Suzuki and then followed that one with a Datsun 1200 motor into another LJ50.
All good, clean(?) fun.
Fri, Aug 25, 2023 2:41 PM
Hi, Folks.
More on doin' what yer can with what yer got - check out the cushion blade on the push cat in this video - and the 'push cat' itself:
https://www.youtube.com/watch?v=-UGPG1mKm1k
Just my 0.02
Fri, Aug 25, 2023 4:20 PM
Hi, Folks.
Just my 0.02
one of the weirdest i saw was a home made "tractor" called old rusty. she was made from the arse end of a centurion tank and some rsj beams had a twin steer front end, a six cyl ruston developing around 1500 hp at 600 revs and 6 44 gal drums for a fuel tank. it had 6 30inch tractor wheels on the back.
at the same event there was a articulated chamberlain made from 2 super 90's with gm power that still got regular use in farming. it also had duals.
Fri, Aug 25, 2023 4:44 PM
Hi, Folks.
Just my 0.02
Hi, trainzkid88.
Is this the one you mean?
https://www.youtube.com/watch?v=AlQWMMenK3M
And then there's this one, with a bit more footprint on the ground and a bit more grunt under the hoodz:
https://www.youtube.com/watch?v=6w-ZnkeXI7c&t=13s
And a 'different' IH rig:
https://www.youtube.com/watch?v=MHrKhsUsS6c
And two old 'poppin' Billys along with the Chamberlain unit(s) - before they got their extra back 'legs':
https://www.youtube.com/watch?v=w5Dv9sCGZKo
Or the Jackie Boy:
https://www.youtube.com/watch?v=WdEI5FimGHQ
And the Black Jack:
https://www.youtube.com/watch?v=0ciRBj3Hm6E
And the Honey Bee:
https://www.youtube.com/watch?v=qQR78kiFOHI
And the Baldwin DP600:
https://www.youtube.com/watch?v=6Qy9BgB8EeU&t=7s
And a converted Bren Gun Carrier:
https://www.youtube.com/watch?v=tPeRdJNJQRw
And the Upton tractor:
https://www.youtube.com/watch?v=HdTnzdXAUik
https://www.youtube.com/watch?v=nHqlYpAbCCM
And the 'grandmummy of them all:
https://www.youtube.com/watch?v=0g3BGVXVUk8
Will that do for starterz?
Fri, Aug 25, 2023 6:11 PM
kittyman1
Hi, trainzkid88.
Or the Jackie Boy:
And the Black Jack:
And the Honey Bee:
that's great stuff Deas...110% correct on INGENUITY...
-also add a dash of Creative Flare,...and Human Spirit...awesome!
Sat, Aug 26, 2023 2:05 PM
Hi, trainzkid88.
Or the Jackie Boy:
And the Black Jack:
And the Honey Bee:
Hi, kittyman1.
I just realized that I 'miscued' on one of those links. Where it showed the HoneyBee tractor twice, the second one was suppsed to be the Zell 214 foot seeder set-up bing pulled by a Baldwin DP600 tractor. I think I have corrected it now.
Part of the interest in that set-up is the way the GPS works. It either tells the driver where to steer the tractor so that the seeder misses the clump of trees - or - it doesn't trust the driver to do it and does the job itself.
Sat, Aug 26, 2023 2:22 PM
kittyman1
Hi, kittyman1.
miss'cued doesn't matter, keep doing you're best...that's progress even if it's roundabout way..who's counting...
Sat, Aug 26, 2023 3:24 PM
