Number of track links on a D2
Showing 1 to 10 of 10 results
microlink
Send a private message to microlink
I’m confused about the number of links on a D2. I have just finished rebuilding the rollers and idlers on 5U10826. The book shows 30 links and a master link, I’d say that makes 31 but the book says 120 bolts are needed, that would do 30 pads not 31. I think the worn out chain I took off had 31 links. I have a 1949 D2 (5U3627) with a total of 30 links. Is the track frame longer on the later D2’s? This is a 4-roller machine not 5.
Sun, Jul 24, 2011 5:17 AM
Mike Meyer
My D2 4U with 4 bottom rollers has 30 links.
regards
Mike
Sun, Jul 24, 2011 5:25 AM
Kelly
Reply to Mike Meyer:
regards
Mike
Microlink,
The information I have is, The later D2’s which were inducted in early 1954 had several changes to the track components. The track assemblies were longer, and two links having been added to make a 32 link chain. They had four (4) rollers but were spaced farther apart than formerly. And, carrier rollers were installed, where they were formerly offered as an attachment.
The early D2’s models of the 3J and 5J tracks were all 30 sections. The only other D2‘s which more than 30 track section were the D2 Tractor--for Highway Trailer Company Earthbore models which had a 35 Section track and the D2 tractor for Trackson Company T2 traxavator which was a 35 section track as well.
Kelly
Sun, Jul 24, 2011 9:01 AM
josh
Reply to Kelly:
Microlink,
Kelly
If your D2 has the larger 23-1/2" idlers it should have 31 links, same for all the J models and U models up to 5U13235 and 4U6372.
Sun, Jul 24, 2011 10:29 AM
Reply to josh:
my 1957 4U with the larger solid idlers has 33 pads per track.
Sun, Jul 24, 2011 9:41 PM
microlink
Reply to josh:
Josh, thanks for heading me in the right direction. Now if I was only sure how to measure the idler. The D2 with 30 links has an idler casting number of 1B309 and the tractor in question has an idler casting number of 8F4360. If I measure the minor diameter of the 8F4360 truck it is 22" and the truck step is 3/4" making the major outside diameter 23 1/2", so is this the larger idler requiring 31 links? These are both spoked idlers, not the solid idler.
Sun, Jul 24, 2011 9:48 PM
Sasquatch
Reply to microlink:
My parts book verifies the 8F4360 idler is the optional 23 1/2" diameter one, requiring 31 track links. I would say you've measured correctly.
Mon, Jul 25, 2011 5:56 AM
microlink
Reply to Sasquatch:
Thanks Toby, I have three different D2 parts books, none of them show the optional 23 1/2" idler. This is the first good news in quite a while on this U/C project. Just happens the tracks that I have to put on are 31 links. So now I just snap them on, right?
Mon, Jul 25, 2011 7:33 AM
ol Grump
Reply to microlink:
Just snap 'em on. .riiiiiight😆 I've made a couple of slave pins for various sized critters. .about a 32nd of an inch smaller than the regular master pins. I use those to pin tracks together, then drive the master pins in while driving the slave pins out at the same time. Sure made life a lot easier doing it that way.
Mon, Jul 25, 2011 8:46 PM
microlink
Reply to ol Grump:
Well the tracks are snapped back on. And after being on rabbit blocks for nearly a year she can once again move under her own power. But, as before the nose is a bit low. This 25U has the straight equalizer spring and it looks straight with the machine weight on it. What I find is the wear plate on the track frame is very thin. The spring leaf also is thinned to about half the new dimension. I’d like to build up the wear sheet, what type of material would work for the wear sheet that will not wear away the spring steel? I have considered aluminum, bronze and soft steel any ideas here? What ever I use it will need to be able to conform to the equalizer spring wear.
Sat, Aug 6, 2011 8:05 AM
Reply to microlink:
Most of the ones I have seen are steel.......
Sat, Aug 6, 2011 7:09 PM
Stradsett Park Vintage Rally
Chapter 2 The Link Club's AGM
