Now the work on the D4 begins
Showing 1 to 10 of 115 results
Norm R2,22
Send a private message to Norm R2,22
Got started on the D4 for today. The oil clutch won't engage. The former owner didn't know how to adjust it, so he used the clutch lever to hold it engaged. That I'm sure caused so much wear on the collar that it will need to be replaced. I hope all of the parts will come out the top as there is no way I can get under it. There are a couple of other problems. The clutch housing fills with engine oil so I'll be pulling the flywheel to check the plug (2A3696) to see if it is rusted through or just leaking oil from the end of the cam shaft. Just to add insult to injury the starter has some major problems. The previous owner didn't bother to fix the latches on the pinion. He held it engaged with the pinion lever. As a result the sleeve assembly is warn to the point that the latch, screw and spring on one side is gone. The bar assembly that pulls the pinion in is warn and bent. I have a feeling that I'll be working at a lathe and mill for some of the parts. My back and knees may never be the same.
Tue, Apr 19, 2016 6:30 AM
Norm R2,22
Here are the pictures of some of the damages. One side of the pinion sleeve [attachment=35174]DSCF0447.jpg[/attachment] The other side with a missing latch. [attachment=35175]DSCF0448.jpg[/attachment] The overall look. [attachment=35176]DSCF0449.jpg[/attachment]
I wonder if the sleeve can be saved by some welding, a bit of machining and some new latches, springs and adjusting screws. I'll have to cross that bridge when I get the parts out.
Now to get the clutch out. The split coupler has been removed. When working bent over and at arms length all of the parts are definitely 32oz. to the pound.
Thu, Apr 21, 2016 3:55 AM
Reply to Norm R2,22:
Worst thing to leave a pinion go bad with an oil clutch, all those grindings, most likely the clutch pump is bad, sorry to rain on your parade but found that out on one i rebuilt.
Gary
Thu, Apr 21, 2016 4:19 AM
gemdozer
Thank you received: 25
Gary
You have to drain the housing cluch and check the screen for small pieces and check the oil pump and you should removed the cluch ass. maybe some broken parts inside and if I can help am still have some used parts
Thu, Apr 21, 2016 5:34 AM
Norm R2,22
Reply to gemdozer:
As soon as I get the clutch out I'll tear it apart and see what the damages are. At this point in my life I like to have somebody around, not so much to help, but to call 911. We'll see what happens tomorrow.
Thu, Apr 21, 2016 9:19 AM
old-iron-habit
Amen to that. A lot of us are riding in that boat.
Thu, Apr 21, 2016 10:27 PM
ag-mike
Reply to old-iron-habit:
yep, me tu
Thu, Apr 21, 2016 11:45 PM
mcclaar
Send a private message to mcclaar
[quote="Norm R2,22"]Here are the pictures of some of the damages. One side of the pinion sleeve The other side with a missing latch. The overall look.
Now to get the clutch out. The split coupler has been removed. When working bent over and at arms length all of the parts are definitely 32oz. to the pound.[/quote]
My D2 had the exact same thing happen to it. I had a friend/machinist at work make me a new sleeve and found a replacement pinion latch bar thingy from the Zimmerman boys out in Iowa.[attachment=35179]PICT0564.jpg[/attachment] That was pretty easy to repair but I had the engine removed for other repairs at the same time. You might be lucky with a D4 as I'm sure it has more room to work on it.
D2 4U-2045
Thu, Apr 21, 2016 11:46 PM
Thank you received: 77
Reply to mcclaar:
If it's the same as a D2, it'll need to slide back another 5" to be removed. Do you have that much space with the engine still attached to the transmission? I don't have a D4 service manual so don't know if removal is required. You could try welding the piece back on and straightening the secondary guide in-situ. Worth a go - if it works, you saved yourself some work. I straightened mine even though the engine is out, because it's easier to see if it lines up when it's still installed
Fri, Apr 22, 2016 1:00 AM
Norm R2,22
Bailed out the oil in the clutch compartment with a 16oz cup till I couldn't reach any further. I then used the shop vacuum to finish the job. I removed the pickup tube and checked the screen. The screen was intact and there didn't appear to be any chips or crud in the tube. The flange that bolts to the pump had one of the ears broken but that should be able to be brazed. Now to get the clutch out. Do I start with the bolts on the flywheel or the bolts that hold all the brackets and the pump? The collar that slides to engage the clutch is warn to a knife edge on the front side. That will probably have to be replaced.
Fri, Apr 22, 2016 5:15 AM
catsilver
remove the oil pump first, unbolt the clutch from the flywheel, get some lifting gear on it, then unbolt the bracket and lift it out as a complete unit. It may be best to wire the clutch itself to the bracket to stop it falling apart when lifting.
Fri, Apr 22, 2016 5:20 AM
