Not a real Cat
Not a real Cat
Showing 1 to 7 of 7 results
catrjw
Send a private message to catrjw
I know this is not a real Cat but I have a Agricat I think is a model "F". Does anybody have any info on these? I bought it to save it from going to scrap. It has a hyd. front loader but the bucket is missing. No tags on it. Still like my Caterpillers better! catrjw
Sat, Nov 8, 2008 8:01 PM
d4e
Send a private message to d4e
I have a AGRITRAC same company made by both out of San Fransisco area.
Sat, Nov 8, 2008 8:48 PM
OzDozer
Reply to d4e:
According to my info, there were numerous small crawlers known as Agricat, Agracat or Agratrac. The name and the spelling is often confused by owners, and thereby lies much confusion.
It appears that one Agricat crawler was built by the Agricat Equipment Co of of Philadelphia, PA. Years of production are not listed.
This Agricat was available only with dozer blade and drawbar lift .. no loader.
It was available with either rubber or steel tracks, and could be ordered with manual or hydraulic lift for the blade and drawbar lift.
It was powered with a 9HP, B&S model 23A, single cyl gas engine.
The other, better known Agricat, was built by Joost Manufacturing Co of Berkeley, CA, in the 1950's. There were at least two models, the gasoline model "F", and the diesel model "FD".
The gasoline model appears to have been powered a single cyl Wisconsin, the diesel was powered by a single cyl, air-cooled, 7HP Hallett diesel.
Many have been repowered by other engines, such as Kohler or B&S.
This Agricat was a heavier duty tractor than the PA Agricat, and came with a hydraulic blade or loader as standard equipment. It was available with steel or rubber tracks. I don't believe there was any relationship between the PA Agricat Co and the CA Joost Manufacturing Co.
Here is a 1999-2007 discussion on YTmag that will give you contacts on the Agricat .. one particular contact person you will probably find useful, is Jay Joost, grandson and grt grandson of the Joost Manufacturing Co founders.
http://www.ytmag.com/orphans/messages/2816.html
I seem to recall that Joost were sued by Cat over the use of the name "Cat" (which is a registered Caterpillar name) .. and Cat won, and thereafter, the Agricat was renamed the Agritrac. Jay Joost will likely be able to fill in any details, or correct errors in my info.
I have a spec sheet on the model "FD" Agricat, that I can scan and post, if you wish to view it.
There is guy who calls himself Walt of CA who is an expert on the Joost Agricats, and who has technical info on them. His contact details and more info on the Joost Agricat, are in the following post ..
http://www.ytmag.com/cgi-bin/viewit.cgi?bd=orphans&th=291
Sun, Nov 9, 2008 7:50 AM
Jason 10/D4
Reply to OzDozer:
Can you please send some pictures
Sun, Nov 9, 2008 8:34 AM
D2 Darwin
Send a private message to D2 Darwin
Reply to Jason 10/D4:
Here is another not a Cat Tractor Terratrac for sale on craigslist
http://montana.craigslist.org/grd/906098722.html
Sun, Nov 9, 2008 10:50 AM
Thank you received: 65
Reply to D2 Darwin:
Hi, Catrjw.
You can find more information about these little jiggers over at Yahoo Groups:
http://groups.yahoo.com/group/tracklayinggardentractors/
Mon, Nov 10, 2008 8:15 PM
D4Jim
Thank you received: 16
Hi, Catrjw.
From OzDozer
[quote]It appears that one Agricat crawler was built by the Agricat Equipment Co of of Philadelphia, PA. Years of production are not listed.
It was powered with a 9HP, B&S model 23A, single cyl gas engine.[/quote]
A guy from the St. Francis KS area used to bring one of these to the antique farm shows at the county fairs back in the 80's but have not seen one in years. The one he had was definitely a toy with manual levers to lift the blade on the front and back. The B&S engine sat rather low in front of the operator and the critter had steel tracks. I think it had about a 4' blade and at most maybe 4 1/2'. Nothing covered the engine and the operator sat on top of the crawler above and behind the engine. Not much for looks and could only be used in a yard. Don't know how they came up with the name Agricat for such a little machine. Don't remember a thing about the clutches, brakes etc.
Cats Forever
Tue, Nov 11, 2008 2:43 AM
side-seat
Thank you received: 14
Reply to D4Jim:
From OzDozer
Rick, Give me a call I have some info on the Agricat and I have one also with dozer setup.
Tue, Nov 11, 2008 2:53 AM
