Non Cat For Tc Tractors
Showing 1 to 7 of 7 results
MARTYN WILLIAMS
Hello Tony
My 125 is at Sprockets now ready for the work out.Its first job was to move a Cat cab for Peter.
Aveling Barford GA
D2 3j
D4 7j Dozer
btd6 Drott X 3
B100
I H TD6
Fordson major
Fordson N
Hydrovane 90
Sun, Aug 12, 2007 3:53 AM
MARTYN WILLIAMS
My 125 in Caterpillar heaven
Aveling Barford GA
D2 3j
D4 7j Dozer
btd6 Drott X 3
B100
I H TD6
Fordson major
Fordson N
Hydrovane 90
Sun, Aug 12, 2007 3:57 AM
MARTYN WILLIAMS
Reply to MARTYN WILLIAMS:
Forgot picture
Aveling Barford GA
D2 3j
D4 7j Dozer
btd6 Drott X 3
B100
I H TD6
Fordson major
Fordson N
Hydrovane 90
Sun, Aug 12, 2007 4:00 AM
MARTYN WILLIAMS
Trouble uploading tonight.Picture shows Sprockets D4 and the rear of my 125.If you look close at the rear of the 125 it has 955L painted below the fuel tank !!!
Aveling Barford GA
D2 3j
D4 7j Dozer
btd6 Drott X 3
B100
I H TD6
Fordson major
Fordson N
Hydrovane 90
Sun, Aug 12, 2007 4:09 AM
MARTYN WILLIAMS
The IH 125 on its way to Sprockets
Aveling Barford GA
D2 3j
D4 7j Dozer
btd6 Drott X 3
B100
I H TD6
Fordson major
Fordson N
Hydrovane 90
Sun, Aug 12, 2007 4:15 AM
David Wills Cat 60
Martyn,
At least there was one picture of your IH 125 (impersonating a Cat 955 traxcavator), with a D4 in the back ground to appease the BB membership!
1948 D6 9U
1963 D6B 44A
1970 951A 63K
1940's Le Tourneau S3 Rooter
Sun, Aug 12, 2007 2:10 PM
tctractors
Martyn have I been "at it", already this month I have rebuilt a f/drive on a D8H 68a including a t/frame sort out and a lot of oil leak stopping, Friday I drove to Oxford then stripped out a complety knackerd front idler from a Kobelco 240 ?? (old yellow style banger) then zoomed the L/Rover over to Bedford to replace a front idler in a CAT D7R-LGP, yesterday I had to repair a low-load trailer (Nooteboom) then unload the tractor off its back, this was a Komatsu D65EX-12 , strip down the left hand F/drive as wire had been twisted into the seal group at the back of the sprocket,I used a mini digger to lift all the big bits (JC😎, it was a fair job un-twisting all that wire,I fitted a new set of Duo-cone seals then threw all the bits back together,clipped up the track,checked for leaks , then shot off for home job done, today I am off to Oxford to repair the T/frame on the Kobelco that has spread open, tommorow I am fitting a new under-cart to a CAT 963B tracked shovel in Bromsgrove, then its sort out another V12 Cummins for Justin , at least the rain seems to have eased,
tctractors
Sun, Aug 12, 2007 2:23 PM
MARTYN WILLIAMS
Reply to tctractors:
tctractors
Hello Tony
Looks like you have been very busy,be carefull you don't burn your self out.Karl wants you nice and fit to pull his D8 frames apart.
Cheers
Martyn
Aveling Barford GA
D2 3j
D4 7j Dozer
btd6 Drott X 3
B100
I H TD6
Fordson major
Fordson N
Hydrovane 90
Mon, Aug 13, 2007 1:28 AM
