No pressure indication on fuel injection gauge
Showing 1 to 6 of 6 results
Sweet D2
Send a private message to Sweet D2
Where should I look for problems to resolve no indication of pressure on my fuel injector pressure gauge.
Engine starts and runs fine; I believe it is a gauge problem but are there other things to check first?
thanks
D2 3J68xx
Kern Co, CA
[email][email protected][/email]
Tue, Mar 12, 2013 4:48 PM
catman63
Send a private message to catman63
I had a problem with my D4 only the pressure never went down ... I replaced the gauge... problem solved! I borrowed a working gauge from another tractor to test the problem first. Hope this helps.
Tue, Mar 12, 2013 10:51 PM
Sweet D2
Reply to catman63:
Great Idea. Will try to find one to borrow to test my system and gauge.
thx
D2 3J68xx
Kern Co, CA
Wed, Mar 13, 2013 1:20 PM
Steve A
Reply to Sweet D2:
thx
To start with loosen the feed line to gage while runing to see if you have flow, if you do then remove gage and bench test it using regulated compressed air, start with the pressure low and work it up, not sure what the pressure range is for the factory gage.
Wed, Mar 13, 2013 4:50 PM
Reply to Steve A:
Without doing a Search, I'm thinking its less than 30 psi?
If you do bench test it as Steve A suggested, definitely use a Regulator starting at Zero, then raise it real slow!
Wed, Mar 13, 2013 8:59 PM
Reply to drujinin:
when i bench tested my D2 pressure gauge it maxed out at 30 psi
Wed, Mar 13, 2013 9:51 PM
Sweet D2
Reply to dpendzic:
Super feedback.
Thanks for all the ideas!
D2 3J68xx
Kern Co, CA
Fri, Mar 15, 2013 12:15 PM
| Kingaroy, Queensland
