No 6 shovel motor stuck or not stuck
desoto
Send a private message to desoto
I need some advice. I have a No 6 shovel, 318 engine. Was running fine and idling when it gradually slowed down and stopped. Motor appears to be stuck. Before I take the motor apart is there anything ( transmission/hydraulic pump,pony motor,pinion etc) else that can be wrong/locked up or whatever and
would cause the motor appear to be stuck when it is not. Thanking anyone in advance for their reply. Ed in southern Illinois.
Sat, Sep 13, 2008 11:10 PM
gemdozer
Thank you received: 7
First check the oil did stick ,after if you want to see if the motor is stuck take off the big motor compression and try to turne the fan and if he turne oke and check the coolant in radiator. LET ME KNOW.
Sun, Sep 14, 2008 12:21 AM
desoto
Reply to gemdozer:
Gemdozer
Unable to turn motor over either by fan or a pipe wrench on the front pulley. Water in radiator ok and oil in motor ok. Pony motor runs good but stalls out when you attempt to turn over the big motor. Ed
Sun, Sep 14, 2008 12:38 PM
gemdozer
Reply to desoto:
Gemdozer
Its could be too the hydrolic pump seize or the hydrolic valve is angaged.
Sun, Sep 14, 2008 6:22 PM
| Hartley - South Australia
