No. 6 Cat track loader
Showing 1 to 6 of 6 results
BullDozerBob
Send a private message to BullDozerBob
Can't seem to find much on the internet on the No. 6 loader. There is some info in the Cat books but I don't seem to find much on any survivors. I know it was one of the first Cat engineered loaders.
Anybody got any specs-pictures-engine model etc.
Thanks in advance.
BullDozerBob
Wed, Jun 6, 2012 9:44 PM
Hi Bob,
Your right, don't see much on the #6 shovel.
Here is what little I have and think I know....
#6 10A series built 1953-1955
Turned into the 977D (20A series) (1955-195😎 and then the 955E (1958-1960)
Used the D6 undercarriage and D318 engine.
I couldn't tell you what the difference between models is....all I have for the #6 is the Service Information manual.
Some specs on the 977:
Wed, Jun 6, 2012 10:41 PM
gemdozer
Thank you received: 25
Hi Bob,
The 6 loader is like a D6 and have a 318 motor and am still have a service information for NO-6 SHOVEL
Wed, Jun 6, 2012 11:23 PM
BullDozerBob
Reply to gemdozer:
Did Cat turbo it to get 100 HP? I know that Cat had a "grader/loader" kit for the D318. My D69U27222 had this kit added by the previous owner to save fuel/add horse power for field work. I only pull a 14 ft Goble 2ft diameter disk and it hardy grunts. Just Curious!
BullDozerBob
Thu, Jun 7, 2012 1:41 AM
Reply to BullDozerBob:
BullDozerBob
No turbo was used.
Early units 10A1-10A705 were less hp and rated at 1400rpm
10A706-10A1616 and the 20A's were rated at 1800 rpm along with a 9" dia. fan pulley, governor and spring changes and the 20A's got cam shaped pistons.
For comparison the 8/9U's were rated at 1600 rpm.
Thu, Jun 7, 2012 2:40 AM
David Wills Cat 60
No turbo was used.
Bull Dozer Bob
This is a photo of a No 6 Shovel owned by a collector in the UK.
Regards, David
1948 D6 9U
1963 D6B 44A
1970 951A 63K
1940's Le Tourneau S3 Rooter
Thu, Jun 7, 2012 4:19 AM
lil cat mec
Send a private message to lil cat mec
Reply to David Wills Cat 60:
Bull Dozer Bob
Regards, David
nice no.6 and vary nice DW10!!!
1935 CAT 22 2F4455W
1990 CAT D6H 4GG04120
2012 CAT 272C RED02823
1971? CAT 951B 86J01212
Thu, Jun 7, 2012 6:26 AM
