No. 4 Toolbar Hydraulic Cylinder specs
Mike B
Send a private message to Mike B
Is there anyone that could measure their cylinder on their #4 toolbar dozer and tell me what the retracted length is pin to pin?  Also the shaft diameter ? Reason for asking is this is a new to me toobar and I think that the current cylinders are not correct. They seem too long. From the parts books that I have access to the correct part #s are 1H813 or 4H6711 or 9F3239 and I can't find any specs for those #'s
Mike B
Fri, Apr 7, 2023 3:24 AM
Deebo
Librarian
Thank you received: 105
There’s a couple of no 4 tool bar books in the technical library on the site; not sure if any specs included but might be worth a browse..
 [attachment=71773]BBED14AF-3594-4D67-BAB5-7A400D3F03B2.png[/attachment]
Fri, Apr 7, 2023 6:08 AM
Thank you received: 288
I went into the dungeon this morning. 20” eye to eye per my worn out Snap-Off tape.
Sun, Apr 9, 2023 1:21 AM
Mike B
Juiceman,
Thanks for taking the time to measure. That is helpful. Mine is 22 3/4. So they are too long. They look to be SWECO cylinders and based on the length they are 12” stroke
Thanks again
Mike B
Sun, Apr 9, 2023 2:03 AM
