No 3 Hi-way patrol grader
Dozer K
Send a private message to Dozer K
I have what I think is a no 3 hi way patrol cat grader. It used to have steel wheels on spokes, and before I got it someone cut them off and welded car wheels on it. I am wondering if anyone has found modern hubs that would fit original spindles which are 1 3/8 inch on both ends.
Thu, Mar 26, 2026 10:07 PM
Busso20
Thank you received: 31
Dozer K, could you attach a few pictures? someone my chime in with assistance
Sat, Mar 28, 2026 11:39 PM
duanetyler
Send a private message to duanetyler
That sounds like a really interesting old machine. If it’s a No. 3 Hi-Way Patrol grader, you’ve definitely got a piece of history there. The original steel spoke wheels getting cut off is pretty common on older equipment, unfortunately.
For the 1 3/8" spindles, you might have a few options. Some people have had luck adapting trailer hubs or agricultural hubs, especially from older farm equipment, but it usually requires machining bushings or sleeves to get a proper fit. Standard modern hubs typically won’t match perfectly without modification.
Another route is checking with vintage machinery forums or salvage yards that deal in antique graders or early road equipment-you might find original hubs or something closer to a direct fit. Custom machining a hub to fit your existing spindles is also a solid (though more expensive ) option if you want to keep things as correct as possible.
If you can share photos or more measurements (bearing spacing, spindle length, etc.), it would be easier to narrow down compatible options.
Mon, Mar 30, 2026 3:03 AM
Thank you received: 140
Hello, duanetyler.
I have just removed the UN-related link from your otherwise possibly helpful post. DON'T put UNRELATED links in your posts or your post WILL be deleted and you WILL be blocked.
Mon, Mar 30, 2026 4:20 AM
